Do Evo's have issues with crank walk ?
Old Dec 24, 2008 | 10:21 AM
Rez90's Avatar
The only motors that technically were "plagued" with crankwalk were the 4G63's the 2nd gen eclipse's (95-99) and not even all of them dealt with it. More like 20-40% of modded 2nd gens dealt with it.
Since then, there have been few reported issue's. On evos, there is one or two here and there, but to real pattern like there used to be.
I wouldn't lose any sleep over it.
hopper's Avatar
Originally Posted by wevo1985
ive replaced other motors that wherent of mitsu that had crankwalked on customers. its possible for any motor to walk.
I agree, As my first post reads. But I believe its safe to assume hes referring to the DSM era, and the 4g63 in particular
Old Dec 24, 2008 | 10:22 AM
hopper's Avatar
never said i was def on that. just what ive heard.
Just trying to help here....
Old Dec 24, 2008 | 10:25 AM
MuslimEvoFreak's Avatar
It's cool hopper, don't worry about it! This is why this forum is here. Also, if there is a case of crankwalk, how are you able to tell and how long does it take to destroy the thrust bearing?
Old Dec 24, 2008 | 10:26 AM
wevo1985's Avatar
no problem
Old Dec 24, 2008 | 10:29 AM
wevo1985's Avatar
ive never had one of mine walk on me but ive had a customer with a hyundia walk so bad that the oil pump was leaking. i was able to actually move the crank up and down by hand.
Old Dec 24, 2008 | 10:31 AM
Under warranty if something like this happens? Does the entire engine assembly need to be replaced?
Old Dec 24, 2008 | 10:39 AM
wevo1985's Avatar
that one did. it was still uner warr too. but i would think that the crank would get damaged and that block to. depending how bad the damage is, a machine shop might be able to repair it possibly
Old Dec 24, 2008 | 10:46 AM
MitsuJDM's Avatar
I wouldn't even be thinking about crankwalk. Yes, it can happen. You know what else can happen? You could walk out of your house an be hit by a heat seaking missle. See my point?
Old Dec 24, 2008 | 11:18 AM
hopper's Avatar
Well the entire assembly is sooner or later attached. Usually the first sign of crankwalk is some nasty engine noise. and your clutch will start acting goofy. Sticking to the floor not releasing.
Old Dec 24, 2008 | 11:36 AM
nicolas916's Avatar
I had two 4g63 motors crankwalk on me in my 2nd gen eclipse. Both times the machine shop told me they were trashed. Oversized paperweights.
Old Dec 24, 2008 | 11:41 AM
philevo's Avatar
i've only heard of one evo that has crank walked. It was a long time ago.
Old Dec 24, 2008 | 01:37 PM
gottf257's Avatar
haha +1
it seems like mitsu has fixed the majority of the problems, i havent heard of many evos that have gotten crankwalk
Old Dec 24, 2008 | 03:01 PM
05ah8james's Avatar
I've only seen it happen on a friends GSX from a loooong time ago. I have heard it was from lugging the motor, and use of really heavy clutches in the older 4g's
This is hearsay, please dont except my word as truth. I'm sure more experienced dsm'ers could tell you if this is true or now.
Old Dec 25, 2008 | 04:56 PM
Yogi_B's Avatar
The only evo engines that have had reported issues with crankwalk are the evo1-4 engines, mitsi redesigned the thrust bearings on the evo5 engines and I haven't heard of any problems since then.
philevo
Oct 1, 2007 08:22 AM
sec711
27
Apr 8, 2007 07:54 PM
hawwk11
11
Apr 19, 2006 02:21 PM
Joeballz
15
Nov 20, 2005 06:36 AM
1stinline
Apr 9, 2002 09:17 AM
