question about tial bov
liveable is it will not do it all the time. for the most part it will be uncomfortable due to bucking or stalling. it will only do it once in a while. the bad thing is there is always that chance it will do it in the worst possible time. i would personally run a stock style until you go big. but thats just me.
hmm...what exactly do you mean by "liveable"? like i said, i'll just get the pipe flanged for the tial. i'll try it out to see exactly how bad it is and, if it is as bad as you guys say, i'll replace it with the stock upper pipe and keep the stock dv. maybe i'll be one of those "success stories"
it won't matter how cool your car sounds if it stalls out and bog all the time!
I wanted to run one of those but didn't think it was worth the tradeoff.Then again it could work for you, I suppose crazyier things have happened!
well the idle is at 1k right now which is higher than stock (iirc). wouldn't this be the same as installing cams? increased vacuum where you need to raise the idle to compensate for it?
i guess i won't know until i install it
Cams don't create vacuum leaks...different subject all together.
Taking my O2 dump off and putting the ported one back on tomarrow, drag season is a long ways off, VTA does get old.
I am actually about to put a dump on. I dont hit WOT near as much as I hit enough boost to make my bov go psh.
So it shouldn't annoy me to bad!
I love the sound of the dump at WOT, just HATE the sound of it at part throttle when the turbo starts to spool, sounds like a gnarly exhaust leak...not bad *** at all...
black-dsm
Mar 14, 2016 12:36 PM
ahendrickson
Dec 5, 2011 01:45 PM
