XEDE question
Old Sep 12, 2003 | 04:50 PM
BeenWaitin4Evo's Avatar
XEDE question
The $90 plug and play harness that you can get with the Xede...doesn't seem so "plug and play".
According to the website, you still have to pull apart the factory harness to remove a wire for the "plug and play" harness for the Xede.
Am I misunderstanding this, or is this how "plug and play" ain't so plug and play any more? 90 bux just seems like a lot of cash to deal out for a harness that doesn't quite live up to its name...
Thanks for any help/input.
Old Sep 12, 2003 | 06:25 PM
Noize's Avatar
EvoM Administrator
I **think** that has actually already been resolved in later a version and you don't have to do it anymore. Looking at it, though, if you have to just pull one wire from the harness, it should be a breeze.
Old Sep 12, 2003 | 06:44 PM
DEL TURBO's Avatar
I just installed my XEDE w/harness. The harness does make it much easier than the previous installation. You only need to unplug 1 wire (light green) from the factory harness. This wire gets rerouted to the XEDE in order to activate the boost control.
The previous method required splicing several wires. I also don't believe it had the boost control feature. If you have a tiny screwdriver (eyeglass repair kit), you can do it within 15 minutes.
If you ever need to remove the XEDE for warranty service, you'll be glad you spent the $90 bucks. It's hard to hide spliced ecu wires.
JMB8606
Jan 11, 2007 04:42 PM
DynoFlash
12
Apr 5, 2005 11:07 AM
doc_evo
Northeast Region
80
Oct 24, 2003 01:59 PM
doc_evo
Sep 25, 2003 09:43 AM
Speedlimit
10
Aug 13, 2003 01:35 AM
