FIC Bluemax fuel injector?
Old Feb 6, 2010 | 03:27 PM
  #31
Ted B's Avatar
You won't make enough power with 95 RON to test the limits of Bluemax 1250cc injectors. If you have a single Walbro 255lph fuel pump, that will reach its limit first, and that won't happen until upwards of 600whp.
Old Feb 6, 2010 | 04:14 PM
  #32
kanyonkid's Avatar
Hey guys, im in the market for injectors also and i was looking at the fic bluemax 2150 series.
my current setup 2.1 destroked 6262.. im looking to get tuned on 3 maps.. 93, vimports/q16 and e85... my question is, are these injectors capable of running through leaded and unleaded fuels? im running 3 maps because ill be using 93/e95 for DD and race for "important" races.. thnx any knowledge will be greatly appreciated.
Old Feb 6, 2010 | 04:41 PM
  #33
Ted B's Avatar
Those fuels won't pose any problems to the injectors, but they will take a toll on the O2 sensor(s).
Old Feb 6, 2010 | 05:13 PM
  #34
zedevo's Avatar
Subscribed ... Very important to know ...
Old Feb 6, 2010 | 05:31 PM
  #35
kanyonkid's Avatar
As far as the injectors themselves.. i have heard a few ppl say when the bluemaxes are being run through with unleaded or leaded fuels the spray patterns arent as smooth and can swell the injectors them selves or seals. can anyone confirm this?
Old Feb 7, 2010 | 05:23 AM
  #36
neilm's Avatar
thanks for the reply yes i have 2 pump set up
i see you have 1250 in your car what fuel are you running ? what hp are you running .
i might run race fuel at some point too
so have no worrys of maxing them out
Old Feb 7, 2010 | 06:39 AM
  #37
Ted B's Avatar
If you have a dual pump setup, you won't have any fuel shortages when you bring that 95 RON to the limit. I'm using E85, so the dual pump setup with 1250cc is enough to meet my 600whp target. All you need to do is find a barrel of poitin at 95% ABV and you can make things interesting.
Old Feb 7, 2010 | 06:46 AM
  #38
neilm's Avatar
thanks again il get them ordered up
e85 is hard to get were i live so cant see me using that
95 is the only fuel i can get at the pumps here so il have to see how it goes
Old Feb 7, 2010 | 02:21 PM
  #39
neilm's Avatar
one more thing do need any driver / wiring mod to run fic 1250cc
thanks alot
Old Feb 7, 2010 | 02:29 PM
  #40
Ted B's Avatar
No, they are low impedance, and therefore are a direct swap.
Old Feb 21, 2010 | 02:39 PM
  #41
8UpUrV8's Avatar
Straight from FIC's site regarding 2150's and Q16
"DO NOT USE WITH "Q" or OTHER OXYGENATED FUELS."
Old Feb 21, 2010 | 03:19 PM
  #42
fre's Avatar
fre
I would be curious to know your base fuel pressure and your duty cycles once you tune for 600whp on E85. Your fuel pumps flow a bit better than my inline setup, but I will be curious as to how much.
I would be even more curious to see your trap speeds once your tuned on E85 (if you drag race it) and then get your duty cycle/base pressure. Right now I am tapped out with my 1150s @ 50psi base pressure at my current trap speed.
Old Jul 21, 2010 | 11:13 AM
  #43
Appauldd's Avatar
Reviving this thread for a little info on the 1450cc Blue Max injectors.
I need scaling and latency values to input for my car. Base on my crude interpolation of the given latency values below is what I have come up with.
Scaling = 1329
Latency values
4.69v - 2.352
7.03v - 1.968
9.38v - 1.656
11.72v - 1.392
14.06v - 1.152
16.41v - 0.96
18.68v - 0.792
Given values from FIC
8v - 1.75
10v - 1.56
12v - 1.35
14v - 1.17
16v - 0.98
Any input would be greatly appreciated.
Thanks.
Paul
Old Jul 21, 2010 | 12:06 PM
  #44
nonschlont's Avatar
Scaling = 1329
Latency values
4.69v - 2.352
7.03v - 1.968
9.38v - 1.656
11.72v - 1.392
14.06v - 1.152
16.41v - 0.96
18.68v - 0.792
8v - 1.75
10v - 1.56
12v - 1.35
14v - 1.17
16v - 0.98
Thanks.
Paul
this is what Ive found on them...
Originally Posted by jid2
PHP Code:
FIC Bluemax 1450s
Scaling (92 oct) 1329 (E85) 1008
Latency: From the data sheet included with the injectors
2.784
2.112
1.680
1.368
1.176
0.984
0.816
Originally Posted by EvoIX2240
PHP Code:
FIC Bluemax 1450s
Scaling (E85) 943
Latency
3.072
2.328
1.848
1.512
1.296
1.080
0.888
Old Jul 21, 2010 | 01:56 PM
  #45
scorch's Avatar
excellent data thanks!
