Advice for 300whp daily driver?
Old Jan 15, 2009 | 10:03 AM
shivaswrath's Avatar
Originally Posted by GgreyEVOIX
Well after years of debating what to do I've decided to mod my EVO IX now that there are tons of options for aftermarket mods like cams, tbe, etc......
This is my daily driver so my goal with it is to have a safe and reliable 300whp on pump 91, I'm only going to run on pump fuel. I'm not looking for peak numbers either, I want a fat and useable powerband. Over 90% of my driving is on city streets so a fat powerband is very important. Also I live in Southern California so I have to and also want to keep the noise down.
I have two setups in mind, both with stock turbo and stock cat-back exhaust:
#1 Open source tune, DC downpipe, Invidia 02, ETS 3'' FMIC, ETS LICP & UICP, ETS intake, Walbro FP, Hallman MBC
#2 Open source tune, GSC s1 cams, DC downpipe, ETS LICP, walbro FP, Denso 720cc, Hallman MBC, ARP head studs & rod bolts
I'm leaning towards #2 but I want some advice from you guys. Is there anything you would change or add to reach my goals? I'm sure doing the cams will net me gains under the curve which matter most to me.
I'd do #2 minus the injectors - you'll make your life more complicated with tuning having those injectors, unless you plan on running a BBK or FP turbo of some sort down the road.
I have the same setup otherwise, DD with power listed below - I'd only add an ETS I/C to that setup to increase efficiency and lower chance of knock as you start pushing more warm air (with higher boost). . .
Old Jan 15, 2009 | 02:13 PM
VtexGt3's Avatar
Originally Posted by jjm4life
300whp and the oem clutch is nothing to be concerned about
youve been on evom since 2005, you should look around some more and realize that it doesnt take much to reach 300whp esp. on a evo9.
i said if he gets cams and all that. not just 300 whp. I'm well aware of what a OEM clutch can do and what it can't.
Also I didn't say he would just hit 300whp with cams exhaust intake and a tune. So please don't just post comments that point out what other people say based on rhetoric and contribute nothing of use to the actual question or thread.
In any case I agree with the last 2 posts. it doesn't take much for you to make 300whp. but if you've got the budget go for your second setup it'll make more power.
Old Jan 15, 2009 | 02:23 PM
Mr. Evo IX's Avatar
A TBE, mbc, and tune will get you to around 300whp on 91oct if your tuner is any good.
You dont need injectors with the stock turbo unless your going to try and run e85 or something. Not to mention the IX cams are pretty decent and are well suited to the stock turbo. Before I put cams in I would save for a decent FP red setup.
Old Jan 15, 2009 | 03:10 PM
dsmbruno's Avatar
y r u guys telling this fellow evo owner to go spend money if all he wants is 300whp?
a tuned evo9 with a MBC and a good tuner will get him 300whp. An updated intake will do it. If you want to make sure, just get an exhaust or downpipe.
Old Jan 15, 2009 | 04:00 PM
spdracerut's Avatar
300whp is pretty cake on the IX. This is what I'd do:
76mm Works DP
Drop-in air filter
Tune
That's it.... and it'll be just as quiet as stock so you don't attract any attention. If you want a bit more power, get a high flow cat, and it'll still be stock-like quiet. If you want a bit more power than that, get the Works Stealth muffler and you'll still look completely stock, and only be a hair louder than stock.
Old Jan 15, 2009 | 05:34 PM
Rnm's Avatar
Rnm
I remember I made 299whp/310wtq with just a MBC, test pipe and a tune all while still sounding like stock.
Old Jan 16, 2009 | 12:09 AM
mr.paick's Avatar
on my 9....
downpipe, exhaust both 3 inch, intake, licp, ets 3 inch IC, EBC and fuel pump.
I netted 318whp and 305wtq.
keep in mind....
stock cams, stock cat and stock 02 housing.
you'll reach 300 no problem...its all in the tuning.
Old Jan 16, 2009 | 12:28 AM
Casper.'s Avatar
I am selling a K&N drop in filter for cheap. Send me a PM if your interested. IT came off my evo 9 not long ago.
Ill let it go for like 25 shipped if that sounds good.
Old Jan 16, 2009 | 10:19 AM
getcha's Avatar
Are you looking to have "space" or support later on? Or are you looking to spend as little as possible?
I think moderation is a good choice here..
Old Jan 16, 2009 | 11:23 AM
GgreyEVOIX's Avatar
Money is no issue here, I just want to start off minimal and enjoy it step by step. I've had tons of fun when my IX was stock and it has been super reliable thus far. I still want it to be just as reliable but with a little extra power. I eventually want to run a 35R but thats years away, I just don't want to go from stock to a 500whp set up right away. I want to enjoy the evo stage by stage starting with the stock turbo and bolt ons.
+1 I agree about doing mods in moderation
Thats what I learned when I had my wrx, I started off small and went through all the stages and eventually ended up with a big turbo set up.
Old Jan 16, 2009 | 11:31 AM
GgreyEVOIX's Avatar
Originally Posted by mr.paick
on my 9....
keep in mind....
Who tuned it?
Old Jan 16, 2009 | 08:13 PM
mr.paick's Avatar
Who tuned it?
tuning tech
Old Jan 16, 2009 | 08:16 PM
sparky's Avatar
If you live if SoCal why would you risk running catless ala DC DP? Even with a HFC you should be able to hit 300 fairly easily, plus it'll be quieter.
Revobasher
Sep 27, 2015 04:41 PM
Hollywood_Evo
16
Mar 11, 2012 05:33 PM
phrequenc
33
May 28, 2011 03:19 PM
RedLanEVO
15
Jan 27, 2009 07:00 PM
xturdfergusonx
Nov 23, 2008 09:51 AM
