Sand-like particles in Engine Oil?
Old Jan 15, 2009 | 01:09 AM
C6C6CH3vo's Avatar
Send out a sample. Filter the particles and see if they dissolve in water
Old Jan 20, 2009 | 10:30 PM
kyoo's Avatar
The particles did not dissolve in water. They did not get picked up by a magnet.
Culprits I'm looking at are cam wear, leaking coolant, dirty air filter, and fuel dilution, in order of most likely to least likely.
There is also a factor of the debris coming from the bottom of the car while I was changin the oil, the bottom of the car was touching the outer edge of the oil pan. That being said, the oil pan edges are about 2 inches high and 2inches wide all around, and I definitely saw some of this stuff comin from the oil filter.
However, the "bronze" particles I saw I have concluded are leaf. So I'm not sure what's going on there.
I've decided I'm going to run the car for 500 more miles, drain the oil and have a look. I've already sent in for oil analysis.
Just to make sure, my oil should be pretty black by the time I get to 500 miles, correct?
kyoo
Jun 13, 2019 05:40 PM
kyoo
17
Oct 11, 2010 06:59 PM
kyoo
Apr 20, 2010 02:42 PM
kyoo
49
Apr 5, 2010 06:54 PM
kyoo
Apr 14, 2008 11:50 PM
