View Poll Results: What would you do?
Install a stainless steel clutch hose only
28
30.11%
Remove restrictor only
8.60%
Both, the benefits are too great
51
54.84%
Neither, it is unnecessary
6.45%
Voters: 93. You may not vote on this poll
Get stainless steel clutch hose or remove restrictor?
Originally posted by Thoe99
So your understanding is that with stock clutch, it is better to remove the restrictor, but with aftermarket, you should have it?
Well, what do you think about me taking it off for the stock clutch now, and putting it back on when I do replace the clutch for a better one? Is it easy to put back on?
From what I can tell, it isn't too easy to put it back in at all because you kinda have to pry it out of the hole that is in. Getting it back up in there the same way it was, seems difficult.
Hmm...that changes things then. I'm just gonna replace the hose for now; safer bet. If anything, I can always take it out later. I should get the hose in the mail tomorrow.
That would probably be the smarter thing to do. I mean if you are definitely going to replace the clutch with something stronger like a twin plate then you should leave the restrictor in so you aren't tearing your tranny up too bad when you do.
Re: Get stainless steel clutch hose or remove restrictor?
Yes, I've read those huge threads that talk about this subject, but I'd like to hear mainly from those who did one or the other -- replacing the clutch hose with a stainless steel one and/or removing the restrictor. I'm debating on whether or not to remove the restrictor, since it voids the driveline warranty.
line in about 7k or so. I drive the **** out of the car and now have over 8500 miles on it without so much as a hiccup. No more smell of burning clutch after removing the restrictor... not a single ground gear after the line, where I was grinding fast 1st to 2nd shifts on occasion before.
The clutch line in the Evo is over 2ft long. That's long enough to provide too much slack. Some people say the rubber hose, being that it's rubber and so long, will balloon up, causing the driver to experience notchy shifting since the clutch doesn't fully disengage. But most importantly, the long rubber hose dampens a lot of the vibration, causing the driver not to be able to feel the engagement well. Here's the big thread on it:
https://www.evolutionm.net/forums/sh...threadid=35497
Here's the thread on the restrictor removal:
https://www.evolutionm.net/forums/sh...threadid=30664
Originally posted by StriktlyBidness
I asked the dealer that installed my twin-plate clutch to remove the restrictor while they had everything out and they said that it would not be a good idea because if the clutch line has to be bled, it would never be the same.
Use a mity-vac on the bleed nipple to pull the fluid and air out. You may also have to bleed the master cylinder and slave cylinder.
To bleed the master:
0. Put a mity-vac on the bleed line with a good vacuum on it.
1. disconnect the master cylinder plunger from the clutch pedal assy
2. Fill the reservoir all the way, and have someone on hand to fill it.
3. Open the bleed.
4. press in on the master cylinder plunger until it hits bottom.
5. Close the bleed.
6. Let the plunger back out SLOWLY!
7. Repeat from 2 a couple more times.
8. Reconnect the plunger to the clutch pedal.
Then bleed the clutch line all the way as you normally would.
Then bleed the slave cylinder.
0. Put a mity vac on the bleed line with a good vacuum on it.
1. Push the slave cylinder plunger all the way back into the slave cylinder housing.
2. Open the bleed.
3. press in on the clutch pedal.
4. Quickly, with the pedal pressed in, tighten the bleed.
5. Let the clutch pedal out SLOWLY!
6. Repeat from 2 a couple times.
Then again, bleed the clutch line all the way as you normally would.
The mity-vac prevents air from getting back into the line.
That will get you a rock-solid clutch hydraulic system.
i say do both along with upgrade the clutch. but before yo udo that learn how to launch a car without a restrictor. the tranny will hold trmendous power.... if you launch right. i have torn up 5 speeds before.... but they were only rated at 200 horse power(that is the reason why they blew...stupid borg warners and gm) and i had a kevlar cluth. this tranny is rated well over 350 hp. no need to worry till you start adding power. but the most important thing is to learn how to drive. that same tranny people are hitting low 13's on they just launch nice and soft. my car was way undergeared which put to much stress on the whole drivetrain. i also twisted my drivesaft with that tranny if that tell you anything.
Hey man, knowing your situation ....... you are much better off changing the line to a steel-braided only! There is no need for you to remove the restrictor since ...
1. This is your 1st stick-shift car
2. You do not launch or drive aggressively on a reg basis
Over time you will become a pro in reference to driving a manual AWD car .... but right now I think the restrictor is perfect for your situation ... since you are still learning how to drive it.
Hey, I'm even still debating to do this ... and I've been driving manual cars for a long time now.
putting back the restrictor is not only possible but very easy...i tried to put it back when i was taking it out just to make sure if i needed to i could....but i like it out MUCH better...i have the ss line also
well, im decided now. the SS line and restrictor is coming out. I have the stock clutch and dont plan on replacing it with after market, -(only if It wears out)- I am getting sick of the notches between gears every now and then. I have been drivin' sticks since 12 years old, and know I can drive da thing
and I am getting sick OF SMELLIN THE CLUTCH!!! lol ....
