BBK Full/E85 vs FP_GREEN/C16.. FACTS!
Old Jan 16, 2009 | 09:53 AM
  #106
OKIX's Avatar
edited.......deep sigh....
Old Jan 16, 2009 | 09:55 AM
  #107
9sec9's Avatar
yeah, You sometimes have to put on the flame suit LONG before you make a post. I've never been one to shy away from controversy, nor one to stand in a line, just because everyone else is already lined up. Robertinaustin, I agree with your comparisons statements. With that in mind, why are almost all posts about anything invariably ending in a 'comparison' statement? Simply put, it becomes a point of reference and nothing more. Dynos are the same. A point of reference at a moment in time at a reference point in space. Nothing more. The back-to-back, identical testing is the best way to compare. Not using hype nor subjective comments. What I would love to see is a back to back test of current technologies using first same pump fuel, then race fuel on each. That way, we can see what the latest turbo technology yields, then how each of those technolgies reacts to the different fuels. Is that even possible? The Red's too big to compare, the Greens old technology, the BBK FULL is new technology than the Green, but the Lite is too small to compare to the Green. It would be nice to see a more equal comparison, but not sure if even that is possible. Oh well, good discussions with lots of 'details' brought out on both sides. No harm done.
Old Jan 16, 2009 | 09:56 AM
  #108
2k4EvoVIII's Avatar
Okay i see where Tom is coming from now. And i have a better understanding the reason for this thread now. But as TOM and everybody else already knows we would have to know air conditions of both runs along with a bunch of other variables.
I think somebody needs to get to Daves and do the back to back test. IMO i think the results are going to be pretty surprising and more evenly matched then what is posted.
Old Jan 16, 2009 | 10:00 AM
  #109
GST Motorsports's Avatar
9sec9,
See post #103: https://www.evolutionm.net/forums/6577881-post103.html
You might want to take another stab at your pencil overlay.
Old Jan 16, 2009 | 10:02 AM
  #110
9sec9's Avatar
Originally Posted by GST Motorsports
9sec9,
You might want to rework your pencil overlay skills.
You are showing that the BR plot has higher torque from 4000 on over the BBK but the BR hp matches the BBK hp up top when both torque plots are different, which is impossible.
Torque=hp.
If the BR torque is higher than the BBK torque at a certain RPM, then the HP will be higher than the BBK hp as well.
(Torque * RPM) / 5252 = hp
oh and btw, did you really just do dyno overlays between two different dynos with a pencil?
I know, my art skills need a tune up. Some of the data had to be extrapolated and in the middle of doing that for myself, I was writing code for one of my customers. I keep 3 or 4 computers running simultaneously, Unix, Windows XP and Windows Server. Since logs were used for the data penciling, my art work could be to blame. I'll take responsibility for that.
Old Jan 16, 2009 | 10:09 AM
  #111
9sec9's Avatar
Bryan, when extracting 'numbers' from your chart, I gave EVERY advantage to a higher number to the GST plot and the lower number to the Buschur plot. If there was ANY question as to what the number was, I tried to make sure that I didn't understate the whp of your pull. That's why my statements clearly stated the numbers I was using. A fat Number 2 pencil, small differences in the higher rpms makes for an easy appearance of being closer than they really might have been. I'll post up the earlier comparison of our Green vs Davids and you can see how close I was on my art work. I guess now, my penciling skills for my own use will be called into question. If the chart doesn't work for you, maybe the numbers would be better to use.
Old Jan 16, 2009 | 10:13 AM
  #112
Well if the torque curve is correct, then BR's HP should be higher, so if anything, you are selling BR's short.
Is your pencil dyno running the newest updates?
Shouldn't our time be better used than comparing two different cars, with two different fuels, with two different engine managment, with two different tuners, with two different dynos, in two different states on a pencil overlay chart?
Old Jan 16, 2009 | 10:14 AM
  #113
Shacochis06's Avatar
wouldnt it still be fair to say a bbk vs green dyno testing from BR the bbk would prolly still come out on top since its alot "newer" and has alot of hours R&D with the past year Chad has put into it......it dont make sense to take the orginal badasss stock appearing turbo vs a turbo that took the green and made it better....just dont see the purpose of that test..
i mean the Green has been out what almost 2-3 years now?maybe more?....every year this community keeps inovating itself with newer bigger things and thats how we've got street cars into the 8's this year....i just dont see the purpose of that test....just look at the facts people that 9sec9 has posted and GST..
Old Jan 16, 2009 | 10:29 AM
  #114
evodood's Avatar
Here's the picture of the comparison I did, BEFORE making any posts. It was for my own analysis, so all points of reference, notes, etc were made for my own pleasure. I think it's worthy of pointing out also that the two GST plots were 3rd gear (slower spooling) and 4th gear (quicker spooling) pulls. The penciled plot is Davids in 3rd gear. Notice the higher peak torque was reached at a higher boost level, yet the rpm points of both the 'dis-similar' turbos was nearly identical, even though the Green had a higher point to reach. The obvious is that the Green made more power at higher boost until they reached the 30.5 psi mark, then they were both making the same boost. Shortly thereafter, the EBC (or was it the turbo??) held higher boost, yet the power was much closer. Again, what would have made the difference 3 years ago? Cams, both are/were using very good cams. Other subtle differences, but both fairly well modded and tuned by professional tuners. So what would be the differences. New technology on the BBK vs 3 year old technology on the Green. EBC vs MBC. Anyway, the reasons for me making the comparison becomes a little clearer. As for the idiots and personality conflicts, please, let's keep it on the details, after all, that's where the devil lives.
comparing numbers to numbers is one thing but ignoring the fact that both machines interpreted/recorded those numbers differently (just because they may both be mustang dynos doesn't mean they read the same) under different conditions, makes the overlay usless.
Old Jan 16, 2009 | 10:33 AM
  #115
sprytsi's Avatar
wow
Old Jan 16, 2009 | 10:41 AM
  #116
ssteve's Avatar
Oh wow, this thread is full of loss. I still don't get the point of any of this. Different cars, different tuners, different everything. Then pencil doodles? What is going on here? The madness! There will never be a true fair comparison between the two, they are different turbos with different parts etc. One could very well make more power with parts combo A, and the other make more power with parts combo B. As well as manufactures castings etc. I really don't see the point, and if I was to buy anything based off the "data" in here. I wouldn't buy **** cause a stock IX turbo is right there with both. So since Mitsubishi shames you all and we all already have that turbo maybe CBRD, and FP should just give it up and call it quits?
Old Jan 16, 2009 | 10:48 AM
  #117
9sec9's Avatar
Here's our numbers on a comparison of JUN's vs HKS on the GREEN. Notice the quick spool up. Only comparision here is to show how quickly the Green CAN spool up, just with cam change and slight tune difference. SAME TURBO. That's how easily a spoolup on the same fuel can be changed.
Here's the dyno of our back to back pulls with same tune, cams but ported vs unported head. This is another one of my reasons I stated a 15 whp difference in favor of Davids car 3 years ago. Unless the GST tuned car also had a ported head, but I assumed not.
added:Sorry, lost the 'copy/paste', should have used my pencil
Now, finally, the answers probably to Bryan's 6000 up, wtq/whp issue. If you read one of my posts I mentioned how Davids car made more whp than ours did from 6000 to 7000 rpms. My art skills obviously used MY whp when I extracted my whp artwork onto the GST plot. As you can see, Bryan was dead on with the problem at 6000 up. With that in mind, the whp difference is even greater on Davids Green. Our dyno pull also clearly shows how we had peak torque by 3900. I think our peak boost was reached earlier, but this chart shows the difference between our car and Davids in Nov 2007. Had I used ours, the lower torque/whp/rpm difference would have obviously been even greater. In summation, back to back comparisons is still the only way to be making comparisons. Even using AVERAGES isn't indicative of your individual results. By the way, the notes on the sheet are Davids, with the rpm/FPGREEN notes being mine.
Old Jan 16, 2009 | 10:53 AM
  #118
JKav's Avatar
Apple, meet orange.
Old Jan 16, 2009 | 10:59 AM
  #119
9sec9's Avatar
Originally Posted by JKav
Apple, meet orange.
I don't disagree, that's why all previous comparisons mean nothing. This just proves that for every point made, there can be a valid counter point, until both comparisons are equal. What it does point out is the devil can be in the details AND the fact that spool up is not only turbo dependent, but tune and part dependent. Maybe greater than has been previosly noted on several occassions. Spoolup can be manipulated (or tuned in/out) at will.
Old Jan 16, 2009 | 11:01 AM
  #120
crcain's Avatar
Is anyone looking at these tags on the site now?
"pencil dyno ftw, tom's not an idiot, worst thread of 09"
Anyway I kept seeing this 40k reply thread of a new CBRD secrest sauce turbo and I thought it was all fluff but then as it turns out CBRD obviously made a great turbo so that is cool. Some healthy competition in the stock appearing category can only be good for us end users.
I'll still recommend the Red though as hot damn a 9.5 ET is saying something.
