rpms drop at idle? need help
Old Jan 18, 2009 | 05:33 PM
lilmarf's Avatar
When my car is idle at a stop light or in my drive way. The rpm's tend to drop and go back up. it does this frequently. Some one told me it might be my alternator?
Old Jan 18, 2009 | 05:35 PM
wevo1985's Avatar
could be a vac leak as well. how much do they drop?
Old Jan 18, 2009 | 06:09 PM
lilmarf's Avatar
well it idles at 1K normally and then drops maybe .3k lower
Old Jan 18, 2009 | 06:13 PM
wevo1985's Avatar
does it surge, what mods do you have if any? also do you have a tune?
Old Jan 18, 2009 | 06:21 PM
lilmarf's Avatar
i have a esplir jgt 500 exhaust, custom downpipe, 02 dump, k&n intake, custom intercooler, ets licp, forge mbc, and ya im tuned pushing 24 pounds of boost
Old Jan 18, 2009 | 06:26 PM
wevo1985's Avatar
ok, i would check for any leaks and also test your battery and alternator. you could be due for a tuneup as well.
Old Jan 18, 2009 | 06:45 PM
biggie5252's Avatar
Could be your fan starting. Evo alternators are pretty small and the batteries aren't the best. Basically, as long as the car stays running, I wouldn't worry about it.
Old Jan 18, 2009 | 08:00 PM
DDATuned's Avatar
Probably your fan coming on.
Old Jan 18, 2009 | 08:04 PM
srcevo8's Avatar
When you got tuned last what did you set your idle to? If you didn't adjust it at all I would recommend that. I bumped mine to 800 or so to accomodate for my cams. It made a world of difference.
...although with the A/C on at a stoplight my RPMs are all over the place....way too low and threatening to stall.
So my advice is to try bumping up your idle to 800-900 and see if that holds it steady. The normal fan won't impact that....but with A/C it will.
jb988
Lancer Engine Tech
20
May 18, 2016 04:53 PM
EvoJoeIX
Dec 26, 2011 01:31 PM
btownsoccer22
Oct 21, 2011 10:31 PM
diiirk@AwdMotorsports
Apr 24, 2008 11:31 AM
apex_silver
13
Jan 29, 2008 02:28 PM
