iddle issues
Old Jan 7, 2008 | 02:01 PM
apex_silver's Avatar
Exclamation iddle issues
when at a stop and idling my evo 8 drops below 1k idle for a split seccond and jumps back yo idle at 1 k any sugg or ideas its like it wants to stall though it never has well yet that is
Old Jan 7, 2008 | 03:18 PM
guess i have a pos car
Old Jan 7, 2008 | 03:52 PM
ColdEvolution8's Avatar
Do you happen to be running a VTA BOV? Or anything like that? That will def cause idling issues.
When does it happen? Like all the time during idle or going from a light to light?
Old Jan 7, 2008 | 04:06 PM
markymark1082's Avatar
My TurboSmart Dual Port BOV did the same until I adjusted it correctly.
Old Jan 28, 2008 | 06:17 PM
my evo is bone stock and i mean everything is stock and it happens all the time cold or warmed up interior lights also fade when it bogs maybe a bad ground ?
Old Jan 28, 2008 | 06:30 PM
the owner before me removed the aftermarket stereo he had before selling it to this is driving me crazy
Old Jan 28, 2008 | 07:22 PM
evokel's Avatar
i have the same problem. spark plugs maybe?
Old Jan 29, 2008 | 06:10 AM
maybe all the silver ones do this lol ?
Old Jan 29, 2008 | 06:19 AM
lords3t's Avatar
you normally idle at 1k? Warmed up? Perhaps the 8's and 9's are different but a bone stock (9 at least) idles between 750 and 850 when warmed up. You may also want to look into the possibility of the ECU being flashed. The previous owner may have kept it stock, but still flashed it (poorly?). Who knows.
Old Jan 29, 2008 | 08:25 AM
no he was **** about the car he was a 45 year old man how do i go about getting it flashed ?
Old Jan 29, 2008 | 12:25 PM
Mr. Evo IX's Avatar
Have you been around other Evo's.. fluctuating idle is pretty normal. Do you have the AC on?
Old Jan 29, 2008 | 12:38 PM
SilverShadow03's Avatar
Wouldn't hurt to flash it back to a stock map just for piece-of-mind. The previous owner being **** or not, I would want to make sure. Another possibility is the idle adjuster screw was messed with if the car was previously tuned and then put back to stock. Might as well check your vacuum hoses too while fiddling around the intake.
Trust me, it happens. I was told my car was NEVER modded when I bought my evo. Turns out that was a complete lie once I started adding parts.
Old Jan 29, 2008 | 02:14 PM
what spark plugs do you recomend ?using ? and what is the torque specs ?
Old Jan 29, 2008 | 02:28 PM
no a/c i rarely use it also is there any tips to get the optimal gas mileage ? im fine with the stock power
browningderek
AEM EMS
73
Mar 2, 2019 08:35 PM
auffy16
Oct 16, 2016 08:11 AM
Brokeassevo
Sep 17, 2016 08:36 PM
fabcas311
10
Jun 30, 2011 12:39 PM
rocketfish
Lancer Troubleshooting
Apr 21, 2011 08:02 AM
