03 oz rally idle/rev problems
Old Apr 19, 2011 | 08:27 PM
rocketfish's Avatar
car starts up just fine will idle fine. When you drive and the start to slow down the revs with fluctuate between 1k and 2k until full stock then will idle fine. Then after being driven and is put in park it will idle at 2.5k. The car just threw a CEL. any thoughts? im thinking it may be IAC?
Old Apr 20, 2011 | 11:53 AM
blaze_125's Avatar
Pull the code and report back.
Old Apr 20, 2011 | 09:38 PM
rocketfish's Avatar
i believe autozone pulled the code as p0507. I swapped in an extra throttle body, problem solved. was either:
1) IAC sensor
2) dirty throttle body
3) leaking seal on the throttle body base
Old Apr 21, 2011 | 07:06 AM
blaze_125's Avatar
http://www.obd-codes.com/p0507
Old Apr 21, 2011 | 08:02 AM
rocketfish's Avatar
Originally Posted by blaze_125
thanks but problem solved, autozone tells you what the code means i didnt know that before hand
audiofan
Oct 9, 2016 04:34 PM
French-frye
15
Jan 1, 2015 11:15 AM
Can_Man
Cobb AccessPORT
Jul 27, 2014 11:36 AM
Tim2s3
10
May 29, 2011 02:10 PM
09lancerGTS
Jan 4, 2009 09:14 PM
