Help.. How can I mount the slim fan?
Old Jan 23, 2009 | 11:26 AM
JakeTheVIII's Avatar
Originally Posted by kekek
I used a similar mounting method for almost 2 years and 10k miles.
Problem is the fan isn't held in place vertically very well. When you hit bumps that fan is bouncing around all over the place, Eventually it will damage the radiator. You can remain blind to it and think it won't happen, but it will. Then you'll be on the side of the road and hoping someone has a used evo rad laying around.
I see what you're saying, it's just hard to explain how zip ties (if you have them nice and tight) would move around more than the fan mounting kit (basically round zip ties). They are virtually the same thing, the mounting kit just has a seperate end to clip on. I've done both methods on more than 3 radiators each.
The way I see it, if you're zipties will end up causing damage to the radiator, the mounting "zip ties" would do the same. The only feasable option at that point is a real mounting bracket of some sort.
Old Jan 23, 2009 | 11:37 AM
Celica2EVO's Avatar
The ties from advanced auto that are made for this will not move. That is what we use at school for all the race cars. That includes are, stock cars, sprint cars. dirt track cars take a rediculous beating and the cans are fine and never move. the Arca cars see well over 100 mph, close to 200 and they are fine. Im pretty sure if they will survive this, they will be fine on an evo.
tolga900
Jul 23, 2016 12:30 PM
JeyEvo
Apr 16, 2016 09:24 AM
jakgal04
Aug 13, 2015 07:32 AM
EvoDan2004
Nov 27, 2007 07:44 AM
Late Apex
12
Mar 27, 2007 04:12 AM
