Evo 9 Block Evo 8 Head
Old Mar 30, 2010 | 08:07 PM
BoostINurI's Avatar
Did this 9 block with 8 head combo a few months ago...also used 8 HG. All i did for the feed line was cut really short crimped an welded. With the oil pressure sender i lengthen the wire to go all the way down to the oil filter housing. Everything is running great no leaks or coolant pushing either.
Old Feb 22, 2015 | 01:48 PM
Jongoff2's Avatar
Is there any problems with sealing an evo8 head on a nine block. I plan on upwards 800whp. Anyone with experience that's done this before?
Old Apr 27, 2021 | 04:04 PM
Triniboy's Avatar
Originally Posted by justboosted02
it works 100%
i have an evo 9 block and an evo 8 head and i use an evo 8 HG. match the HG to the head
So does the evo 8 head works on evo 9?
Old Apr 27, 2021 | 04:21 PM
hutch959's Avatar
you cant take your evo 9 and put an evo 8 head on it.... if that is what you are asking.
you can take an evo 9 block and put it in your evo 8... i
Old Apr 27, 2021 | 05:38 PM
Biggiesacks's Avatar
I think you could if you went stand alone, or swapped in an evo 8 ecu. I can't really think of too many scenarios where it would be a good idea to do all that though.
Old Apr 28, 2021 | 09:49 AM
justboosted02's Avatar
funny this thread came up,
I am now in the process of using an evo 8 block with an evo 9 head
I simply tapped the oil pressure sensor feed for the mivec banjo (pre final block washing of course)
and I still match the gasket to the head
Old Apr 28, 2021 | 04:21 PM
hutch959's Avatar
yes... i know.. i was trying to keep the answer simple since it was a question with not alot of details.
bakuro117
10
Dec 27, 2016 06:16 AM
Ichigo0Soul
May 23, 2016 09:02 AM
Dkaficky
Oct 6, 2015 11:48 AM
Foxmaster
Oct 26, 2012 10:00 PM
atilla
37
Nov 8, 2010 05:11 PM
