Bottom end swap set for 10/15 & I need your help!!!
Ok, first things first. I have a 2003 EVO 8 5speed GSR.
I currently have blow-by & what I assume to be, lifter tick.
Comp test is about 80psi across the board.
The car has just over 56k on original bottom end.
I'm pushing about 545hp/406tq @30psi on E85.
I ordered a new OEM bottom end, OEM oil pump, OEM water pump & TopLine lifters. Which should be arriving some time this week.
I also have a new cosworth crank scraper & kiggly racing HLA plate to install.
I'm looking to do the swap next Thursday 10/15 through Sunday 10/18.
I'm trying to find out any and all oiling modifications that I can do to the motor & head before I throw everything together & install it.
Is there specific casting flash I should knock down/off, in the head or block?
Should I polish any specific surfaces or passages?
Any & all information/links/break in tips/personal experience is appreciated!!!
On a side note;
I'm also in the works of filming the 4 day event, in my garage, via time laps video.
On a side note;
Why did you spend all that money on an OEM short block?
There were a few reasons I opted for a new OEM block. Minimal downtime of vehicle.
The fact that I can take out the factory block. Send it out to be built up w/ new parts. While I still have a running & driving car. Then when the 2nd OEM block rings crap out(or whatever), I can send that one out to be built, all while having a freshly fully built one on hand. & then repeat!
I agree with the previous posts about using another OEM block. Only way I would do it is if you knew someone with one and got a good deal. You're going to be putting something in, that at your power levels, you are just waiting for something to happen to again.
I was similar power and just broke a rod. One mess up on stock block and over boost or something like that and you're likely to do damage. I wouldn't risk it.
Plenty of shops will send you a motor, and you send yours back once you get it....
I wanted a spare bottom end, so I got an OEM one.
Instead of paying a core charge of 2k+ & then spend another 3-5k on parts and machine work & weeks of waiting. I figured this would be my best rout to go.
So instead of criticizing me for buying a spare motor...
How about we jump back to my original post & everyone flood me w/ information on what I'm looking for! 😉
kovs04sti
Jan 11, 2012 01:19 PM
EvOSean06
12
Jul 9, 2010 01:58 AM
Gruppe-S
Evo 'For Sale' Engine Internals and Drivetrain
94
Apr 8, 2008 11:47 AM
djevoawhp
For Sale - Cars For Sale
Sep 15, 2006 12:57 AM
