external wastegate on stock turbo
I have preloaded my stock WGA with the integral WG to 21#. I just don't see the stock WGA preloaded to 21# as being much different from an external gate set at 21#, IF they both have to pass through the same restrictive wastegate bypass port in the 16G's turbine housing. To prove me wrong, show me the comparative dyno plots!
I've run internal gate with o2 dump and external gate on my DSM, sound identical to me.
As indicated previously, you can pre-load the actuator or get a higher pressure actuator to adjust the cracking point. Going through the headache of converting to an external gate on a stock type turbo is just pointless for 99% of the people running them.
ive heard rev's seen pics of his set up and talked to him about it its not a hard set up if you can fab which i am very good at so its easy for me now as for power adding i dont know if it will, but sice my stock wastegate just took a poop on me i need a new one so why not go external
A question is why go external if your still using the internal gated turbine housing (the limiting factor). The internal WG area adds turbulence to the scroll inlets, just might defeat any purpose of fitting an external. Who knows? Just a thought though
if you run it the way i want to and the way rev made his then you don have the area that the internal wastegate used to flow to, that all omes out and a flange is welded roght over the flapper whole and the flapper is removed
haha i like the fast part but we barely get cold wheater and that means no snow which mean ill never be able to drift!
but i will hve an external wastegate soon haha and i no theres not to many fans aout there but o well
turbodreamz21
19
Jan 21, 2012 06:41 PM
RevMoto
40
Jan 17, 2009 09:48 PM
You FLA guys are eccentric, JK
