WTF is happening
Old Jan 24, 2009 | 05:55 AM
MR_Evo_Rob's Avatar
What was your E/T's on Green? You do know, you can get down the track faster without raising your speed. Not considerably faster.
I know this isn't the case, but if you were to spin the whole track, your speed would be really high but your E/T would be high as well. But if you have traction, you'll have a lower E/T and probably a lower MPH.
Old Jan 24, 2009 | 08:43 AM
justa4banger's Avatar
the turbo has no shaft play watsoever... and yes im on e85...man im really pissed off....
Old Jan 24, 2009 | 08:44 AM
well... my 60ft are the same and i couldnt get any faster than 12.7 at 111
Old Jan 24, 2009 | 09:01 AM
jmelocik's Avatar
I am pretty sure Mark hit the nail on the head saying to do a boost leak test.
Don't forget most of the stock turbo records were set with VIII turbo's because of the high efficiency of the compressor wheel, Robert at FP will back me up on that. The compressor maps back this up also.
Josh
Old Jan 24, 2009 | 09:26 AM
thxs for all the replies..but damn...its like i spent 1k$ to trap slower..lol... i have the stock manifold not ported would that make me lose top end since the green is bigger than the 8 and same with my cams??
Old Jan 24, 2009 | 09:27 AM
dsmfan95's Avatar
Originally Posted by justa4banger
but the thing about it is would it still hold boost like it does if it has a boost leak??
Yes it can, but the turbo is having to spin harder in order to keep the same boost.
Old Jan 24, 2009 | 09:35 AM
that makes sense
Old Jan 24, 2009 | 09:39 AM
thepoint4life23's Avatar
do you have any way to log it. if so you should logs and it maybe a little help to find out whats going on
Old Jan 24, 2009 | 09:55 AM
bump for any more input on this
Old Jan 24, 2009 | 10:28 AM
even with with a non ported manifold you will still be making more power from the old set up to the new one. and should of still ran faster.
Old Jan 24, 2009 | 11:15 AM
sonicnofadz's Avatar
Try logging to see if you are knocking down the track. Check for boost leaks, and do a compression test as well to see if your engine is toast.
Old Jan 24, 2009 | 11:37 AM
Tvo's Avatar
Tvo
Man, after looking at your mod list, if I was to make any suggestions, it would be that ur stock IX BOV has crapped out and not holding the boost and actually causing a boost leak through your BOV. If I'm not mistaking, the stock BOVs are only good for holding about 25lbs of boost and yours might be worn out from your old setup and cant handle your new setup. I would suggest that if you have any buddies around with an evo and a recirculated aftermarket BOV, to see if they are willing to let you use their BOV to do a test.
Old Jan 24, 2009 | 01:34 PM
i have a aps bov...holds perfect... right now im in the process of taking my car to do a boost leak test and compression test... i doubt it has low compression though..cause when i had my 8 turbo it was trapping the 116mph and than i threw on the green about a week ago than thats when everything went down hill...ill keep u guys posted
Old Jan 24, 2009 | 01:39 PM
Tnnrx7's Avatar
Do the boost leak test and then get back to us instead of us just sitting here guessing
Old Jan 24, 2009 | 02:01 PM
your mean
dont make me more depressed
