Greddy PRofec B spec-II
Old Jan 26, 2009 | 08:39 AM
BadBoy818_818's Avatar
can anyone help me set up the best list on the EBC
the set gain, gain, etc all of it give me a list what i should put on each of the specs,i want the low to be as fuel economic as possiable and the high to be on the highets (safe though) possiable on a 100% stock evo 9 MR btw i switched it to PSI rather then kPA
thnx
Old Jan 26, 2009 | 08:41 AM
mhchan218's Avatar
im sure there is a thread on this in the how to section already. you should search there. good luck.
Old Jan 26, 2009 | 08:48 AM
already have they didnt have exactly what i wanted
Old Jan 26, 2009 | 09:08 AM
bump!
Old Jan 26, 2009 | 09:46 AM
JakeTheVIII's Avatar
Just mess with it. There's not a certain setting that works best on all cars.
Obviously the more fuel efficient version would be lower boost, and vice versa for high boost.
EDIT: searched with "profec" in titles only, and came across this. Might be useful:
https://www.evolutionm.net/forums/ev...b-spec-ii.html
Old Jan 26, 2009 | 10:07 AM
thnx ive already seen that when i searched didnt help , well id like to mess with it but im afraid i might mess something up because it is stock and i dont know how much to crank everything up to........
Can some 1 plz fill this out on LO put the lowest possiable and on HI put the highest possiable thats safe for a 100% stock evo 9 MR
LO
SET:
GAIN:
START BOOST(SET GAIN):
WARNING:
LIMITER:
HI
SET:
GAIN:
START BOOST(Set Gain):
WARNING:
LIMITER:
Thnx
Old Jan 26, 2009 | 10:13 AM
555R's Avatar
first off do you have a tune on your ECU
as said before
everycar is different
there is a thread on this already with many settings...what works on my car
might not work on your car
i have low and hi set at 48 and 58 which equals 20.3psi and 23.8 on my car
i know others have different sets higher and lower at the same psi
you have to play with it
it took me forever to get these settings and i did that only after it was tuned for 24 psi
Old Jan 26, 2009 | 10:18 AM
there is no tune on the car yet ....ur sayin you have your car set to 23 psi lets say what about all the rest ....... what do u fill out the rest?u dont just leave the rest what ever its left on ...... can some1 jus fill out what i posted and i'll work on it from there to try to set it the best i can
Old Jan 26, 2009 | 10:29 AM
LO
SET: Try around 40% or 50%
GAIN: 5
START BOOST(SET GAIN): 8
WARNING: doesnt matter-try 15psi
LIMITER: 22psi
HI
SET: 60-70%
GAIN: 8
START BOOST(Set Gain): 8
WARNING: 15psi
LIMITER: 22psi
Try that...go from there tweaking stuff, and seeing what effect it has, if any.
When I was tuned on stock turbo, my set was 73%, and that made around 24.5psi.
Gain was set somewhere between 5-8, and start was set at 8. Warning was at 15 or 20 psi, all that will do is light up or beep or something when boost exceeds your mark.
Old Jan 26, 2009 | 04:20 PM
theshadow's Avatar
Do you have a boost gauge?
If not you can read what boost youre hitting from the profec itself as long as you have the PEAK BOOST setting turned ON.
Then start with a low SET value (say 30 or 40 - doesn't matter, ust start low) and the minimum GAIN value and work from there.
Do a test run each time - keep reading your peak bost level off the Profec screen right after you lift off the gas abd keep raising your SET value each time until the Profec shows you that you're boosting to the level that you want (according to the screen on the Profec).
Once you have the right amount of boost (your correct SET value) you can try raising the GAIN value one notch at a time until your boost comes in as quick as possible without spiking, fluttering or otherwise behaving badly.
To set up your SET GAIN, you need to turn off your Profec, do a test run and see what your wastegate pressure is (do a test run and read the boost level off your boost gauge). Then turn your Profec on and set your SET GAIN just a little lower than your wastegate pressure. Should work OK. You might need to fiddle a bit to get it just right.
Most important thing is to start low with your SET and GAIN values and raise them slowly - SET first then GAIN and SET GAIN to fine tune spool.
I may be wrong but that's how I (eventually) set my Profec up. Good luck!
Old Jan 26, 2009 | 09:03 PM
BluEVOIX's Avatar
If you can wait a week or so I'll tell you know how I set mine. I just recieved the Greddy Profec B Spec II today and I will install it with my exhaust this weekend.
Old Jan 27, 2009 | 07:42 AM
mt057's Avatar
I recommend to put the set gain at the point in which your wastegate is just about to vent. I have mine at 190 because I have hp acutator. You want to run form wastegate as long as possible for best spool I believe then use the ebc to force it to hold further. Watch out for the limiter. Mine will spike 2-5 psi over what it is set at.
Old Jan 27, 2009 | 08:34 AM
LO
GAIN: 5
LIMITER: 22psi
HI
SET: 60-70%
GAIN: 8
WARNING: 15psi
LIMITER: 22psi
thnx the answer i was lookin for
Old Jan 27, 2009 | 08:38 AM
thnx also another good answer
Old Jan 27, 2009 | 08:44 AM
sure , i mean my car is still not working, im waiting till my clutch disc arives from japan and then they'll jus fix the car while installing it , i got 2-3 weeks left till it arives , yours is stock right?and not tuned?i dont think the exhaust system will give that much of a diffrents without a tune so yeah tell me what u set it on , and also can some1 tell me what boost spiking is?
