Greddy PRofec B spec-II
sure , i mean my car is still not working, im waiting till my clutch disc arives from japan and then they'll jus fix the car while installing it , i got 2-3 weeks left till it arives , yours is stock right?and not tuned?i dont think the exhaust system will give that much of a diffrents without a tune so yeah tell me what u set it on , and also can some1 tell me what boost spiking is?
This was Mine keep in mind this is on a full bolt car and its different for all cars
LO
SET: 25%
GAIN: 5%
START BOOST(SET GAIN): 150
WARNING: 250
LIMITER: disable
HI
SET: 87-92% depending on wat hit 30-33lbs (race gas tune)
GAIN: 5%
START BOOST(Set Gain): 221
WARNING: 350
LIMITER: disable
I disable my limiter because I don't want the boost falling once it hits the warning and 25% made about 20lbs for me on pump gas and I always left at 5% gain because I noticed if I set it any higher the boost wouldn't spool properly. It would spool 15lbs for like 400-500 rpm then the rest of the boost would come and 5% always would hit 30lbs for me the second I got on it or 20lbs the second I got one it
LO
SET: 25%
GAIN: 5%
WARNING: 250
LIMITER: disable
HI
GAIN: 5%
WARNING: 350
LIMITER: disable
if your car is 100% stock idk why you even bought the EBC as your first mod...
start with on HI
40%
5%
200
210
disable meaning 0
Work your way up till it hits 20lbs might even have to raise it up to 55% or 60% or whatever it takes. idk all cars have diffenrt settings like already mentioned so I wouldn't know what your exact % will be
and for low setting
15%
5%
150
Warning: Doesnt Matter- Warning just means once you go over the boost you set it to it will turn red screen as a warning
start with on HI
40%
5%
200
210
disable meaning 0
and for low setting
15%
5%
150
Evo11V
13
Jan 26, 2007 06:25 PM
