wastegate wont open??
Old Jan 26, 2009 | 10:08 PM
def1's Avatar
I just finished installing my fp green and my wastegate does not open. I shot up to 20 psi and climbing when I should have been at wastegate pressure of like 12 psi. Whats going on? I didnt hook up the boost lines so I could just run the psi off the wastegate spring. The wastegate came already installed on the fp green so I didnt mess with it.
Old Jan 26, 2009 | 10:16 PM
JakeTheVIII's Avatar
If you didn't hook up any lines, then I think that's the problem. I believe you're supposed to at least hook a boost source to the wastegate for it to sense pressure, and open.
Old Jan 26, 2009 | 10:18 PM
GST Motorsports's Avatar
No vac line on actuator = unlimited boost.
If you loop a vac line from actuator to pressure source then it will do wastegate boost.
Old Jan 26, 2009 | 10:26 PM
def1's Avatar
o ok I was under the impression that no vac line would make it run off the wastegate spring pressure.
I just connected my boost controller and turned it all the way down. I dont wanna test it out yet tho because Im dumb and forgot to put a gasket on the j pipe and now my turbo is leaking oil. But tomorrow when I fix that problem I am going to give it a try and hopefully hooking up my boost controller will fix the problem
What im wondering tho is oil supposed to be leaking from the j pipe? I thought only air goes out through there.
Old Jan 27, 2009 | 05:32 AM
I thought that too...maybe check your oil feed and return lines. The return line gasket is notorious for oil leaks, I've heard a few people having leaks from oil seeping past the threads on the oil return bolts, so you need to make sure that's sealed and tight.
Old Jan 27, 2009 | 08:36 PM
cfdfireman1's Avatar
Find somebody that knows what they are doing and get some help before it's too late.
Old Jan 28, 2009 | 04:24 AM
sparky's Avatar
Is this a new Green, or a secondhand unit? Do you know whether it is equipped with the FP HD actuator, or the stock IX actuator? The FP heavyduty(HD) actuator is a 16-18 PSI minimum actuator, so if this is the actuator on your Green, it'll be tough getting that particular actuator down to 12#. In contrast, either the stock WGA, or a Forge unit can be adjusted down to 10-12 PSI.
BOOSTINAT30PSI
24
Feb 8, 2017 07:48 PM
def1
Feb 2, 2017 10:34 AM
AKW89
Mar 31, 2013 08:43 PM
the mark w
29
Jul 14, 2011 08:09 PM
FastAzzEvo
25
Nov 6, 2007 09:00 PM
