From HTA35R to Full Race Borg Warner Setup
Old Feb 11, 2009 | 05:27 PM
  #136
a1091156's Avatar
Originally Posted by Mike@AwdMotorsports
I was doing nothing wrong.. I called Several BW dealers when i was in the market for a BW turbo and they told me straight forward DO NOT EXPECT THE TURBO TO LIVE AT 50+ psi with a 270 thrust bearing.. i wasnt doing anything wrong.. Im not going to throw anyone under the bus but i spoke with sponsored RACERS, 7 Second Car owners that use BW and they said " sorry we dont have anything we could be sure would last at those boost levels from BW..
To be fair I just checked both Compressor maps for the S400's. The 71mm goes up to 60Psi for a very small portion, anywhere to the right of that (75+lbs/min) and it will overspeed immediately.... with max Flow at 40psi btw.
The 74mm goes up to 45psi with max Flow at 25psi.
I'm not sure why you want to push 50psi out of these Turbo's since max Boost doesn't equal max Flow..... but maybe I don't know what I'm talking about....
You do realise that as soon as you go anywhere outside the compressor island to the right side of the surge line, the compressor will overspeed exponentially....
And last time I checked, less max Boost was actually a good thing for Intake port velocity's during off-boost.
But if you still want to try these at 50+psi, then feel free to have them modifed to a silicon nitride BB centre cartridge here > http://www.billetturbochargers.com/
Old Feb 11, 2009 | 05:36 PM
  #137
AWD Motorsports's Avatar
Why did i want to push it to 50psi?? Because i wanted to make 800+whp and still stay within my Class rules for last years nopi events.. Since that didnt work out i ran a 4294 turbo and push upwards of 55psi when necessary w/o an issue...
Yes i am aware of billetturbocharges.com.. The only Florida distributor is Big daddy performance and we happen to sponsor their supra.. If we able to get BB cartridge with the BW compressor wheel our shop evo would fly.. For now though we are running PTE 6262 @ 49psi and havent had issue making near 800whp and running 8's..
Mike
Old Feb 11, 2009 | 05:48 PM
  #138
M3EvoBR's Avatar
And how did you actually check?
Old Feb 11, 2009 | 06:15 PM
  #139
a1091156's Avatar
Its common knowledge that you need about a 10% increase in CSA per 1bar of Boost, to keep peak power where you want to. Therefore off-boost port velocity suffers the higher the Boost level you require to run at a certain rpm.
Luckily for us, the ports are quite High-speed and already designed for 1.5+Bar so the effects are not as severe as they are on older Cylinder Heads.
Old Feb 11, 2009 | 09:07 PM
  #140
crispeed's Avatar
So it's common and you've checked!
Old Feb 12, 2009 | 10:26 AM
  #141
Audi2ptzero's Avatar
Originally Posted by Full-Race Geoff
get us one!!!
If you want one for testing Geoff let me know.
Old Feb 12, 2009 | 10:53 AM
  #142
typac69's Avatar
how about more info on the thread and build itself then going off topic as this is......
Old Feb 12, 2009 | 02:11 PM
  #143
Geoff Raicer's Avatar
yes we need one to test! pm or email me
Old Feb 12, 2009 | 05:11 PM
  #144
Emailed you.
Old Feb 18, 2009 | 08:55 PM
  #145
JohnBradley's Avatar
So FOR THOSE OF US that are actually interested in what Mitch found with the 91-79 can we return to subject?
I am not going to deny reading all of this thread start to finish was enlightening but I see a lot of info(or disinformation depending on viewpoint) that is currently being spread on other boards.
Kurt, thank you for your technical if not brief outline of what to expect with BW from both a customer service aspect and the actual tech.
Geoff, I want to go to ***** Wonka's Turbo Factory now...I just need the golden ticket.
a1091156, While I dont know your name, your to the point and accurate SAE descriptions of flow function was not lost on me and I appreciate it. I am curious if you have ever checked the mach index on a new style 4G head?
Ted, Good as always. I look forward to the actual street test of this turbo myself since I dont drive on dynos regularly.
Mitch, Please continue with the 91-79 if you would be so kind. The 83-75 is promising so the 91 must be better.
Everyone else, I know I am a no one but if you dont have anything to contribute that directly relates to this turbo test please take it elsewhere.
Old Feb 21, 2009 | 11:39 AM
  #146
thanks for the response, this thread went way ot, so we started a new thread here:
https://www.evolutionm.net/forums/ev...vids-dyno.html
we will probably make a new/final thread once testing is complete
Old Mar 6, 2009 | 10:51 PM
  #147
03whitegsr's Avatar
http://www.sae.org/technical/papers/972775
If you can afford an unbiased answer.
This paper is about low speed diesel applications. I wouldn't hold it as gospel.
Not worth the $15, IMO as compared to most other SAE papers I have read, it really wasn't that through.
It's also worth mentioning, I believe one of the engineers at Full-Race did his master's thesis on exhaust manifold design. Speaking of which, Geoff, is there a way a person may be able to view the research that was performed?
Magnumpsi
Feb 25, 2011 04:50 PM
Magnumpsi
Evo X Dyno Results
28
Dec 19, 2010 07:10 AM
Magnumpsi
Evo X Dyno Results
Apr 4, 2010 08:45 PM
Magnumpsi
May 6, 2008 04:20 PM
Magnumpsi
36
Apr 25, 2008 09:37 PM
