Bosch 1000cc injectors on an Evo
if you have to open the throttle that implies too rich and might be tune-able.
with the colder weather, are you guys finding your car is able to warm start easier?
As I have said before, I am one of the lucky ones whose car starts easily fairly constantly.
But then the pacific northwest isn't known for heat spells.
I do not believe its starting rich or tuning - from the trend I am noticing the car is not even getting fuel on my first set of cranks, because when i stop and the crank again the car will fire up no problem and the pulsewidth matches that of the first set - now why wouldn't it fire? I have my wideband setup that it doesn't lose power under cranking and I can watch my wideband gauge and the first set of cranks it doesn't show a rich condition that its over fueling..
It seems something is locking the injector to not open properly or function properly on that first set of cranks and the car just isn't getting proper fuel....because once i stop cranking then start again it fires like it should.
just an FYI... the car didn't seem to start ANY better with the magnus than without it.
Also,
this week in particular my car is starting like ***. NOTE: VERY cold.
Two things:
1) For everyone: I haven't had time to do a thorough followup test, buy my initial test of relieving the fuel pressure in the rail until just before starting seems to stop the issue. Can a few other people try disconnecting the FPR from the rail and leaving it disconnected until just before trying a warm start?
2) Can someone build and send me a voltage divider that converts 16 V to 5 V so I can log voltage at the injector?
It would probably be cheaper to just go grab two resistors from radio shack then to have somebody send you them.
Any idea what kind of electrical impedance is on the input?
A 10k Ohm and a 22k Ohm resistor in series should do it and should be standard values.
If that doesn't work, I could probably build something up real quick at work on Monday.
You will need high precision resistors for best results. If you do a 330 ohm in series with a 100 ohm and tap in the middle with the 100 ohm connected to ground and the 330 ohm connected to VCC, that knocks down the voltage by 0.3125 or 14 volts will look like (14*0.3125) = 4.375,
Two things:
I will relieve the fuel pressure after start up and see if it starts better.
Some interesting information I ran across reading up on injectors today... http://www.stealth316.com/2-injectortypes.htm
Upon reading this I am going back to Dan's original assumption as this being the driver circuit issue... when converting to high impedance injectors...
With peak hold injectors/resistor pack, the circiut allows higher current flow through the injectors solenoid which open the injector faster.
When you put in the high impedance injectors this drops the initial current flow through the injectors down, thus taking longer for the soleniod in the injector to "charge" and to open the injector.
The only way I can see combating this is to change the cranking primer initial pulse ( to crack the injector open faster)... I will try this later today...
