Bosch 1000cc injectors on an Evo
Best bet is just to use uint8 and uint16 scaling where appropriate.
actually when I started using mrfred's advanced fuel control options my increment values are the same as travman's. Nothing below 0.9. What definitions need to be changed?
taking off the pcv valve next to the oil cap helps after shutdown. Of course put it back on when you start. Seems to be a hassle though. I've tryed it several times with success. Starts right up in a couple of cranks. However if i've been boosting quite a bit, even with this method the car sputters to life. Starts the first time every time. Now the question is why???
Has anyone here installed a check valve/ one way vave on their fuel line to see if it helped? I was also thinking of doing this but not sure if I can get the right size to fit the oem line. So far I've found aeromotive's high flow check valve, but i don't think it will fit without the proper AN-6 thread.
I looked at their website and found this... http://www.amsperformance.com/cart/A...mance.com.html
would it work with one of these?
http://www.summitracing.com/search/B.../?autoview=sku
also, anyone try the pcv valve mod with good results?
That's Easy... "Alt key" + " [" to decrease value by 1%. I have had it down to .1.
I also put this table back to stock values and start-up didn't change one bit so it did nothing for me...
I saw the fittings on their website but couldn't see how they would work with the check valve, however...
We got a huge snow storm here and its been too cold, at this point im waiting till spring to work on this - i have been working almost a year on it so whats another month or 2?
.Yes that check valve and AMS looks like it should work for you both 6AN....it will add a few inches to the length but shouldn't cause a kink or anything, give it a shot.
Thankfully E85 season is about 2 months away for me and the starting is much more livable on E85 - not good, but just more livable.
That's wierd
not that <.9 may help, but I have had luck increasing the value way above what i want and then stepping back down by 1% to get the values I want. Another way is just to type ".X" in an any text application and cut/paste it in. I guess I would consider driving to Florida lol.
^ i think the .9 your talking about is the standard main cranking enrichment table. The one travman and I are having trouble with are part of the advanced fuel control tables provided by mrfred.
I don't think those tables are the issue. It must be temp related because the car starts up right away during a brief stop using the standard values.
The total cost of the check valve set up is gonna be almost 200 bucks.
Do you guys think if i just clamp the fuel line prior to starting it up will work? I was a little worried about damaging my fuel line because of the teeth on my vise grip. I mite need to wrap it with something softer, but do you think that will be enough force to prevent it from leaking back. If it did, it would be just like a check valve but for free lol.
worth a shot imo.....i clamped my return before with no issues testing my FPR.
i think i'm gonna clamp the fuel line underneath the back seat and see if that works because it's smaller and more flexible than the one under the hood. I'll report back to see if I get any results.
