Help! I think my transmission went bad.
Old Feb 3, 2009 | 04:34 PM
06evoIXseBLACK's Avatar
I have an 06 Evo gsr 5 speed trasnsmission. I got it with 5k miles on it. It just hit 12,500 and my clutch went out....so I had a guy change it. When he got done I took the car around the block, everything worked fine, then I took it around again and I was turning around when the stick shift became extremely hard to move. I couldn't put it in reverse or fifth gear.....the only gear I can put it in with ease was 1st. It goes into second, third and fourth with alot of difficulty. The stick shift is slanted to the left when in nuetral. I know it's not the clutch because it goes in with out grinding and all the cables are connected....when I disconnected the cables, the stick shift moves freely.....so it has to be something in the tranny I just don't have the slightest idea....
Old Feb 4, 2009 | 07:05 AM
PeteyTurbo's Avatar
Sounds like the guy that did the install bent your shifter cable mounts on the transmission..Take a look and see if it is out of wack..
Old Feb 4, 2009 | 08:29 AM
boosted2x2's Avatar
disconnect the cables from the transmission and try to shift the gears manually with hour hands. if it is stiff then there is a issue with your transmission if it is not stiff then there is a issue with your cables
Old Feb 15, 2009 | 11:40 AM
armyfoodsucks's Avatar
it's also possible the tech adjusted your clutch incorrectly too. you should have that checked as well.
Old Feb 15, 2009 | 09:08 PM
xspsi4's Avatar
My friend put in one of those el cheapo e-bay clutches and hte same thing happened to him.
Old Feb 16, 2009 | 11:39 PM
turns out the shifter cable linkage came apart for some odd reason..thanks for the tips.
MarkChamorro
Jul 14, 2012 10:20 PM
IntegxX
12
May 2, 2012 07:21 AM
fengzhaoxi
Mar 2, 2010 02:48 PM
MTRJunior
Jan 20, 2009 04:29 PM
slt
15
Jun 17, 2005 01:10 PM
