Test Pipe Help...?
Old Feb 3, 2009 | 10:24 PM
i8urvtec's Avatar
Test Pipe Help...?
I just bought a catback setup and i was looking at the test pipe and it doesn't look like it has a bong for the o2 sensor so what can be done if it doesn't have one...Drill and weld a bong and get a cel fix from ebay...? really stuck on this one any help will be appreciated..thanks
Old Feb 3, 2009 | 10:27 PM
porsherules911's Avatar
yah you can do that or does the catback have a bung on the midpipe? Some exhausts have it on the midpipe.
Old Feb 3, 2009 | 10:28 PM
Evo_Hustler's Avatar
from what I know... the evo 8 has the 02 bung on the actual catch-back right after the flange & the evo 9 has it on the cat... so what your saying should be correct...
Old Feb 3, 2009 | 10:35 PM
i8urvtec's Avatar
Ok so im gonna order the cel fix now and when i get the test pipe I will cut and weld the o2 bong and see what happens..If i dont do this what will happen will the car go on safe mode or something like that..dont want to lose power here you know what i mean...
Old Feb 4, 2009 | 02:53 PM
srcevo8's Avatar
If you cut and then weld a bung+CEL fix then you'll definitely be fine.
If you don't then you'll just have to live with the SES light being on all the time. The car doesn't go into limp mode or anything. It just throws the error code.
Old Feb 4, 2009 | 03:22 PM
manofhonor's Avatar
hahahaha ceiling cat ftw
Old Feb 4, 2009 | 03:32 PM
Psquared's Avatar
don't "order" an o2 fix. They're like 5 bucks for 2 of them from any auto parts place. And yeah, just go to a shop, they can drill and weld you on a bung. Local shop here only charges 20 bucks and is done in 20 minutes.
Old Feb 4, 2009 | 03:33 PM
Psquared's Avatar
Oh yeah, you're looking for a spark plug Non Fouler. It will need to be drilled out to 1/2" inside.
Old Feb 4, 2009 | 04:14 PM
9sec9's Avatar
I've done this exact same thing on a few occassions. It works great and never had a cel problem. By the way, just for grins I'd leave the 'Bong' in the bedroom and put the Bung on the car. JK
