Tomei Arms Turbo installed!!!
Old Feb 13, 2009 | 07:31 AM
  #151
mr.green's Avatar
Still wanting to see it on 93 octane. Out me on the 93 results waiting list.
Small town, no e-85 around.
Old Feb 13, 2009 | 09:14 AM
  #152
AWD Motorsports's Avatar
Working on getting a test car ASAP..
Mike
Old Feb 13, 2009 | 10:23 AM
  #153
Dragracer187's Avatar
great numbers, I would take this over a green for sure.
Old Feb 13, 2009 | 10:39 AM
  #154
SWOLN's Avatar
Nice job Mike, CWill, and diiirk !
Old Feb 13, 2009 | 11:19 AM
  #155
sponger_pr's Avatar
That chart shows boost at 35psi. Unfortunately, most drivers here will probably be running 25-28psi. Good numbers but 35psi good lord. Even the green can get good numbers with a good tune, fuel, and 35 psi. Would love to see what the Tomei can do with a more common boost setting. Not that 35 is not done often but not as often as what the majority of buyers will be at. I can already see kids buying the kit, not making 450whp and being upset. Not too many tuners would recommend 35psi without all the supporting mods and good fuel.
Old Feb 18, 2009 | 02:28 AM
  #156
Justin Zingel's Avatar
Any update on this? After some number running your 93 octane....??
Old Feb 18, 2009 | 11:13 AM
  #157
JohnBradley's Avatar
Originally Posted by roger smith
The turbine housing is 10.5 cm.
It doesn't say if it's original design or just mitsubishi copy.
A/R for it is .77 , bigger than I thought and still spools good.
The 79 in the M7960 they say means the turbine wheel trim
60 is the compressor wheel trim.
Also looks like you can buy the parts of this turbo separately + overhaul kit.
But thanks for sharing your findings. I want this turbo too.
These 2 are one in the same. The equation that Mitsu uses versus the rest of the world still is an equation
http://www.stealth316.com/2-turboguide.htm
6 cm2 = 0.41 A/R
7 cm2 = 0.49 A/R
8 cm2 = 0.57 A/R
9 cm2 = 0.65 A/R
10 cm2 = 0.73 A/R
11 cm2 = 0.81 A/R
12 cm2 = 0.89 A/R
Old Feb 18, 2009 | 11:42 AM
  #158
aka.ralliart15's Avatar
I think that this turbo will prove to be a great option for pump and still on race gas and e85 it will continue to perform well, im sure that it will perform better than the green on pump from what we have seen by the test, a ~40whp increase with both turbos almost reaching their peak and still a faster spool by the tomei. I pre-ordered one from billet design almost immidiately after they were tested and I plan to make a pump gas map and a race gas map for the street and track respectively, I'll let everyone know how it feels.
Old Feb 18, 2009 | 11:52 AM
  #159
shuttlegoose's Avatar
any updates?? i too would like to see this turbo on 93 oct at around 25psi with bolt ons. This looks like a daily driver turbo and not all of us daily drive our evos at 35psi (although i do know that some people do, and it is very awesome and i wish i could too lol)
thanks mike and good luck with the test car.
Old Feb 18, 2009 | 12:33 PM
  #160
the new shipment of turbos won't come in until the end of February or even the beginnig of march so we will not see any result till then unless mike or someone else got the first batch and finds a test car because I'm sure diirk won't go to pump gas.
Old Feb 18, 2009 | 12:41 PM
  #161
roger smith's Avatar
Thank you for that info, John
Old Feb 23, 2009 | 05:04 AM
  #162
crcain's Avatar
Presumably power would be closer to the Green if boost was the same.
Also, how many days apart are the baseline Green run to the Tomei run?
What type of tuning changes were made? Was more ignition advance run?
I think the testing posted on EvoM is getting pretty questionable these days. Posting a graph of ignition timing deltas between the runs. And AFR deltas would be helpful.
Old Feb 23, 2009 | 01:10 PM
  #163
stryfetew's Avatar
Love to see some 25psi 93 octane numbers as well..
Old Feb 26, 2009 | 05:53 AM
  #164
EvolNinja's Avatar
Originally Posted by Mike@AwdMotorsports
The pricing is 1695.00 shipped right now.. They come complete with brand new stainless lines, actuator, and Gaskets.. I have 10 i am going to reserve for the next shipment.. Those of you interested i would get in a deposit to get your name assigned to one when they show up.. Thanks!!
Mike
Hopefully you still have that kit next year Mike. I plan on turbo upgrade in 2010 I have a baby coming so I can't do anymore upgrade until next year. But for what I got, I can live with it
Old Feb 26, 2009 | 08:38 AM
  #165
rr06rs's Avatar
You say you can buy the parts seperately.....SO DOES THAT MEAN YOU CAN PURCHASE THE COMPRESSOR HOUSING?????
