FP RED Vs Greddy TD06-25G
Old Feb 6, 2009 | 04:46 AM
gtm_maxwell's Avatar
I am thinking of Upgrade my turbo. I am using TD06-20G kits from Greddy. Any one can tell me if I switch to larger turbo(FP red or TD06-25G) Or even Billet machine a BB TD06 with 60-1 Compressor wheel . which will be better?
As I was hopping to get Spool up faster.. is that mean BB will always be faster compare to normal FP RED or Greddy turbo?( as I am no a Budget hoping not to Spend too much on the Billet Turbo*). what is the lag that I am looking for if I switch the turbo to FP RED or 25G?
Any one use the FP RED on street? how was it, when will the turbo start to FULL Boost? 25psi?...etc
Any infor will help me Decide?
Old Feb 6, 2009 | 05:37 AM
Toxin's Avatar
I think you need to do a bit of reading about terms you are using.
If you're looking for a fast spooling street turbo on a semi budget, go with a FP Green, or a FP Red. Red spools a bit slower but is capable of much higher boost.
BUt from what I gathered in your post, my guess the best turbo for you would be a Green.
Old Feb 6, 2009 | 05:49 AM
supersal's Avatar
hhmmmnnn your sig says EVO 3
So thats not a reverse scroll turbo like the Evo 4-9 - yours should be similar to the old DSM's and its also not Twin Scroll if I remember correctly...
Maybe one of the DSM Guru's can sugest the right FP turbo for your application - I'm thinking somthing like a DSM 50 Trim drop-in solution...
Old Feb 6, 2009 | 08:23 AM
94AWDcoupe's Avatar
I have a 25g you can use with your kit.
sell it for 350 shipped to asia.
Old Feb 6, 2009 | 03:36 PM
hmm.. sound like I should get a BB turbo, any one know how is the lag on the 25G or the FP red? full boost in 4000 rpm? or later 5000 rpm?
Old Feb 6, 2009 | 03:57 PM
EVOIXreno's Avatar
Red around 4200-4500 Peak Torque around 5000
Old Feb 6, 2009 | 04:52 PM
Gary@MellonRacing's Avatar
green or red depends on the what u r going to do with the car
Old Feb 7, 2009 | 04:25 AM
let say we keep the same spec every things same like
1) Same stroket (billet Crank, Forge piston..etc)
2) larger Injector 850cc
3) larger Intercooler.
4) PowerFC ECU...etc
What will be the difference between this two turbo after install ( FP red / Greddy 25G )?
any advise?
Old Feb 7, 2009 | 04:30 AM
RaiN907's Avatar
Those turbo choices depend on what you're plans are for the car, how and where are you planning on driving it, etc.
Old Feb 7, 2009 | 08:25 AM
94AWDcoupe's Avatar
You should start by confirming you have EVO3.
The RED turbo will not fit on EVO 3 without tremendous amount of work. here is a thread of me installing an EVO X style turbo in an early evo. To do this to your car you need an EVO X turbo setup from stock car, an evo RED for EVO X, and a tremendous amount of fabrication skills.
http://www.dsmtuners.com/forums/newb...-10-turbo.html
The GT3071 in the thread is for sale. it spools faster than the single scroll 20g and makes around 25 more HP.
The RED turbo is about same size as 25g. Both turbos can makes 525-550whp on a well setup car. But RED spools faster due to it being twin scroll in design. cost to get red on your car about 4000$ cost to get 25G on your car about 500$.
Old Feb 25, 2010 | 11:45 AM
bandolero's Avatar
Registered User
i have a fp red and it full spool about 3800 i do have cams 272 kelford and this is my daily driver and i have no problems
WraithXt1
17
Apr 11, 2024 03:14 AM
Mauricio Evo IV
11
Oct 31, 2017 12:10 AM
EvoIX89
Oct 12, 2016 04:53 PM
Black_EVO_MR
Aug 16, 2014 06:12 AM
imbest123
Sep 4, 2010 10:05 PM
