Fp Red Boost Creep PLEASE HELP!!!!!!
Old Feb 11, 2009 | 08:14 PM
  #91
dastallion951's Avatar
scratch last post ditch ur hallman for a dejon tool, or check to see if the ball in ur boost controller is sticking...good luck
Old Feb 11, 2009 | 08:21 PM
  #92
sparky's Avatar
He already has lubricated the Hallman, but to no avail. He feels that it isn't the MBC, as he has left the MBC out of the boost control loop by running a hose directly from the WGA to the compressor housing discharge tube's nipple.
Old Feb 11, 2009 | 08:49 PM
  #93
mugen777's Avatar
Originally Posted by sparky
Test it in top gear which will tend to creep more than the lower gears. So, what creeps less with respect to WGA adjustment: all the way tight, or all the way loose? Incidentally what is the ambient air temp when testing?
Honestly there wasn't much of a difference with the preload adjusted.... the boost controller would control the spike. Its around 60-65 degrees here.
Old Feb 12, 2009 | 07:54 AM
  #94
mugen777's Avatar
FP is thinking my car could be out of time. I am going to go check...
Old Feb 12, 2009 | 10:25 AM
  #95
k now since uve lubed up the ball inside the boost controller, i know on the dejon tool theres a plastic piece that use an air hole to help with boost taper..usually from bc to wastegate.... u can see if u have one, and if so enlargen the whole to see if that will help....gl and let me know what happens.
Old Feb 14, 2009 | 01:03 PM
  #96
EvoTio's Avatar
Any progress on solving your boost creep issue?
Old Feb 14, 2009 | 01:43 PM
  #97
Erik@MIL.SPEC's Avatar
He said in another thread he had, but he hasn't clarified what it was in this thread.
Old Feb 14, 2009 | 09:09 PM
  #98
mugen777's Avatar
Sorry guys didn't follow-up in here, Yeah well believe it or not it WAS the damn timing. It was just the last place I thought to check. I had jumped 2-3 teeth. I have a new belt and tensioner on the way just to be safe. But I got it back in time and its rocking solid boost
Old Feb 15, 2009 | 07:32 AM
  #99
sparky's Avatar
You're good as gold again!
Old Feb 15, 2009 | 07:56 AM
  #100
Q@EvoPowerMods's Avatar
Awesome Man...glad you got it figured out.
Old Feb 15, 2009 | 08:35 AM
  #101
mugen777's Avatar
Thanks Sparky and thank you again Q. Never forget to over look the smaller things
Old Feb 15, 2009 | 09:30 AM
  #102
sparky's Avatar
Originally Posted by mugen777
FP is thinking my car could be out of time....
These guys know where it's at. A heads up call!
EDIT: Incidentally do you know whether your belt having jumped had advanced, or, retarded the cam timing?
Old Feb 16, 2009 | 07:16 AM
  #103
Mellon Racing's Avatar
wow, nice save, you owe FP big time
Mikey@Spec-Ops
92
Dec 12, 2011 09:47 PM
berns
54
Dec 15, 2010 12:42 AM
millsyy17
28
May 24, 2010 05:26 PM
Guru
Oct 7, 2009 09:27 AM
AcePitcher11
16
Apr 15, 2009 08:29 AM
