Positives and Negatives of a 4.11 Final Drive Ratio???
Old Feb 10, 2009 | 01:03 PM
PVD04's Avatar
The car will accelerate slightly slower in each gear, but this negative effect is balanced by the fact that you can go slightly faster in each gear. So, for example, 3rd gear acceleration will be slightly slower than with the stock FD, for a given speed you may be in 3rd gear rather than 4th (i.e. ~95 mph).
Old Feb 10, 2009 | 01:08 PM
Boost3dxEvO's Avatar
Its really common sense that the 4:11 would give you slower acceleration since you are going faster in each gear... its like with a big turbo.. you have to give up low end and spool to get mid range and top end.. same concept here.
Old Feb 10, 2009 | 01:50 PM
jxs1984's Avatar
play gt4 or gt5 with a friend, set up the gear ratios/final drive for those two identical cars and race on a straight track for a visual difference
Old Jun 21, 2009 | 09:37 PM
fugiwara's Avatar
any final drive option for 6 speed?
roni4g63
May 29, 2017 11:01 PM
Jacks Transmissions
Jacks Transmissions
12
Dec 28, 2015 08:02 PM
Kraise
Oct 30, 2015 02:35 PM
cficare68
Aug 28, 2015 07:27 AM
Johnboy1065
24
Oct 10, 2011 08:01 PM
