How is the drivability and idle of the Kelford 272 on an Evo 8?
Old Feb 10, 2009 | 07:14 PM
racer135's Avatar
How is the drivability and idle of the Kelford 272 on an Evo 8? Are the Kelford 272 a good choice for a daily driver Evo 8 or are they too rough? How do the Kelford 272 compare to the GSC S1 in Power and drivability?
Yes I have search!
Old Feb 10, 2009 | 07:34 PM
scheides's Avatar
EvoM Moderator
No foking way you searched.
Kelfords are awesome for DD, end of story.
Old Feb 10, 2009 | 07:56 PM
Kracka's Avatar
Both great cams. If you plan on staying with the stock valve springs the GSC S1's would be the smarter choice since they are a little less aggressive though.
Old Feb 10, 2009 | 08:23 PM
racer135's Avatar
Will the GSC S1 be a good choice for an FP Green on 93 Pump? I want a strong fat powerband even if that does not mean any high peak HP numbers.
Old Feb 10, 2009 | 08:53 PM
justboosted02's Avatar
car will assplode with kelfords
Old Feb 10, 2009 | 09:34 PM
scheides's Avatar
EvoM Moderator
lol!
Old Feb 10, 2009 | 09:47 PM
URBANRCR's Avatar
The kelfords work great for DD. the idle isn't bad and they make great power.
Old Feb 10, 2009 | 11:18 PM
evo L's Avatar
nobody has evAr used kelford cams, EVAR!!!!
Old Feb 10, 2009 | 11:22 PM
TS8's Avatar
TS8
If you are worried about drivability with great torque, I would use 264s.
Old Feb 10, 2009 | 11:27 PM
Kdash106's Avatar
EVAR evAr??
Old Feb 11, 2009 | 08:26 AM
racer135's Avatar
Based on lift and duration specs ONLY. I have no info on ramps.
The GSC S1 are a little more aggresive than the Kelford 264.
The GSC has a slighly higer lift on the exhaust but a lower duration.
They appear to be basically the same specs.
GSC S1---------ADV Duration--------Duration @ 1mm Peak-----Lift------------CenterLine
Intake-----------264------------------216------------------11.00mm-------------107
Exhaust---------268------------------220------------------10.50mm-------------113
Kelford 264---ADV Duration--------Duration @ 1mm Peak-----Lift------------CenterLine
Intake-----------268------------------216------------------11.00mm------------107
Exhaust---------270------------------222------------------10.35mm------------113
Old Feb 11, 2009 | 10:06 AM
ch53avitech's Avatar
I thought Kelford went out of business because no one bought their cams .
Theres no way you searched .
vr4gasmtt
Sep 13, 2015 11:08 PM
auffy16
Aug 13, 2015 10:15 PM
EvoGSR8
Mar 13, 2014 01:14 PM
adWRXi
Feb 11, 2010 08:50 AM
racer135
29
Mar 11, 2009 04:01 PM
