Revolver Cams...Yea or Nea?
I have Revolver cams and a Green with the stock MAF and full HKS hard pipes, as well as ported head, ported stock ex mani, ported tubular o2, and 3" DP & cat Del, then 80mm 5zigen cat back and 750cc injectors and the list goes on, and on.....
I am running 25psi. DLL is showing consistant 385 hp 375 tq pulls.
I am still in the process of extracting more power out of the cams and turbo. What I will tell you is the cams are very difficult to get to idle well. I have the idle tuned for 1000RPM and 8* of timing. MAF scaling is still in the works, but I have it now where the car won't stall any more. As for the pulls, they are great. I can get on it in any gear and boost seems almost instant.
I chose this setup becasue I am a torque junky. The revolver cams are highly noted for the low end torque which I agree they give well. The top end power is not as great as other cams out there, but for AutoX and track days, I believe these are the ticket.
The car is so much fun to drive because power is so instantaneous.
If you run the revolvers prepare yourself for a long battle to get them to run great. They are not an easy cam to tune in my opinion.
Chris@nolimitmotors
Evo 'For Sale' Engine Internals and Drivetrain
400
Jan 26, 2017 08:25 AM
erioshi
Mar 29, 2010 03:39 PM
