I need help asap!!!!
Old Feb 20, 2009 | 09:18 AM
03evokid's Avatar
ok so I installed my MBC and fuel pump and boost gauge lastnight. I started it up this morning sounded fine i warmed the car up drove down the road to check the boost presure and i heard a POP like the ICP blew off it was studdering and barly ran... it will not boost at all now....... and barly stays runing.... i checked every hose nothing was off....
I conected the waste gate hose to the boost controler and then tapped into the BOV hose and T off and conected that to the other end of the mbc....(is it possibe the controler is hooked up back words?.. i capped off the hose on the turbo... anyone have any idea what could be wrong ( ps i have 280s installed and and intake and o2 dump and i need a tune bad thats where i was goin when this happend)
Old Feb 20, 2009 | 10:07 AM
Tnnrx7's Avatar
Sooo did you check your IC pipes?
Old Feb 20, 2009 | 10:12 AM
EvoLutionized8's Avatar
sounds like IC piping or MAF didn't get connected all the way... I would check all the piping connections again to make sure they are sealed... GL
Old Feb 20, 2009 | 10:13 AM
Arkitek's Avatar
def sounds like somewhere something came off...search my friend search!!
Old Feb 20, 2009 | 10:18 AM
G20's Avatar
G20
go under and take a peek at your ic hoses.
Old Feb 20, 2009 | 10:19 AM
evo 9 guy's Avatar
I have had this happen before. It was actually the IC pipe on the charge side. At first look it did not seem to be off, but as soon as I touched it, it just moved over and off the IC. I connected the hose back on and all was good to go again.
Old Feb 20, 2009 | 10:20 AM
Tnnrx7's Avatar
Before you even ask, after you check your IC pipes (which is probably the issue) use hairspray to get them back snug and then use T-Bolt clamps so you won't have that problem anymore.
Old Feb 20, 2009 | 10:21 AM
srcevo8's Avatar
I agree with all of the above. Grab and tug on every pipe you can...you should find something with a little give.
Old Feb 20, 2009 | 11:30 AM
RockmanX's Avatar
i think everybody above is right after i installed my injen kit i had the same thing happen loud pop sound when i tested it for boosting could not find the problem for a month then when i owned a aps bov when i went to install it i saw the upper ic was disconnected i bought all new holes and 2 t-bolt clamps for that section bam problem fixed now boosting as usual
Old Feb 20, 2009 | 11:34 AM
EvoDom's Avatar
its your lower intercooler pipe. sometimes even when it does look like they are off, it is. pull the pipe off throw 2 t-bolt clamps on it and call it a day. that simple.
and o yea look up and install guide for an MBC and make sure you have it installed correctly.
Old Feb 20, 2009 | 11:40 AM
RoadSpike's Avatar
So you mean to tell us that you did a boost leak test and couldn't find the problem with the upper IC pipe disconnected?
Old Feb 20, 2009 | 12:36 PM
03evokid's Avatar
GOT IT...... when installing the warbro there is a little plastic thing that slides over the stock nipple i didnt see it wen i took it out so i had to take the fuel pump back out and insert that stock peice..... when hiting alot of psi the fuel would just cut she is running like a champ i was sooo scared thanks everyone for the help!!!
Old Feb 20, 2009 | 03:40 PM
evokid511's Avatar
nice at least youu were able to figure it out
Old Feb 20, 2009 | 03:44 PM
RoadSpike's Avatar
Good find the exact same thing happened to me .
Unfortunately my IC pipe didn't blow off I though i had actually killed my motor .
Old Feb 20, 2009 | 08:08 PM
03evokid's Avatar
dude i though i blew my motor to i was soooo scared
akinnear03
Dec 28, 2010 06:53 PM
Nasty Evolution
13
Feb 19, 2010 07:27 PM
supersal
May 16, 2008 12:52 AM
TREVORSEVOVIII
Nov 29, 2007 07:22 PM
UFO
Sep 11, 2005 06:15 PM
