Injen CAI/Full IC Piping Question
Old Feb 21, 2009 | 08:15 AM
coryco19's Avatar
I just got my hands on an evo 8 wich I plan to mod to high h**l. So I decided to start out with what else but the noob special aka the cold air intake. I see that Injen makes a CAI kit wich comes with full IC piping as well but checkin out the pics it looks as though the piping in the kit changes diameter and gets smaller in several places. Injen claims this is actually Beneficial. Can anyone give me some insight on this product? Thanks in advance.
Old Feb 21, 2009 | 08:20 AM
evokid511's Avatar
it does get smaller when the intercooler pipe connects to the turbo because that turbo discharge pipe is only 2.25" (i believe correct me if im wrong) so the I/C pipe tapers down to meet that size... even though its small in some areas it still helps out
Old Feb 21, 2009 | 09:55 AM
chaotichoax's Avatar
you'll need a tune after installing the intake if you actually want to get your money out of it
Old Feb 21, 2009 | 10:13 AM
shawn360h's Avatar
I have this kit and it does get smaller at the turbo outlet. One thing that i would get would be the couplers that connect onto the IC cause they do not come with the kit. Also it would be a good idea to get constant torque clamps cause ive had problems with the lower pipe blowing off at high boost.
Old Feb 21, 2009 | 10:28 AM
bluebanana23's Avatar
Injen never made a CAI. First was the upper i/c piping along with an intake. Then they came out with lower and upper pipes without the intake. If you have stock battery, then this kit isn't bad but there are some many better options out there. The lower pipe is quite restrictive and Injen is one of the less stellar designs and seems the hype is on the ETS version 2 pipe with claims more power on top of other aftermarket designs.
Old Feb 21, 2009 | 10:33 AM
IceHawk's Avatar
I think I will try the ETS one
Old Feb 21, 2009 | 11:08 AM
RockmanX's Avatar
the lower pipe is the one that matters the upper ic who cares do you want to run small battery or not is the question. I got complete injen kit and have modded the kit to work perfectly now so im not changing just to go though all that again im pefectly happy with my setup now and it will do well for my overall build once im done.
Old Feb 21, 2009 | 12:17 PM
mr.green's Avatar
I have the complete Injen setup on my car. I would not purchase it again. Look at an ETS kit, or a Nisei small battery kit setup. As far as intake setups, Perrin seems to be the latest rage since their filter has recently won the air filter shootout.
Old Feb 21, 2009 | 12:19 PM
Sansone's Avatar
Take note of this OP.
Old Feb 21, 2009 | 01:22 PM
coryco19's Avatar
Thanks for all the input. I think im gonna look into the perrin intake and an ets ic piping kit
Old Feb 21, 2009 | 01:57 PM
metal4all6's Avatar
Try out ETS. I have their intake and IC piping and it looks, fits, and works great!
What part of Philly are you in? I don't think there is anything scheduled right now, but check out the Northeast section for meets in the area We usualy get 10-20 evos at the meets.
Old Feb 21, 2009 | 02:13 PM
coryco19's Avatar
Yeah i'll probably head up to the meet on the blvd on Sunday night. Theres usually a pretty big turnout. Haven't been up there with the EVO yet though.
Old Feb 21, 2009 | 02:36 PM
RockmanX's Avatar
must be nice to have that many evos running around
Old Feb 21, 2009 | 09:51 PM
EVOgirlIX_MR's Avatar
why wouldn't you purchase it again? i have it too and i like it.
sunshdw
35
Dec 11, 2013 06:17 PM
dinok
Oct 14, 2009 12:27 PM
psphinx81
19
Sep 16, 2007 10:05 AM
Thegame
36
Dec 2, 2005 07:27 PM
EVO8.com-Chris
18
Nov 17, 2005 04:30 PM
