What sould i tell the mechanice
Old Feb 21, 2009 | 12:35 PM
dsmbruno's Avatar
Originally Posted by EJEvo
Atmospheric BOV on an otherwise stock Evo? Running it just to let friends hear the "woosh"??
Tell the mechanic he needs to replace the Evo's owner.
That's a good one. I think that would fix all, if not all the problems
Old Feb 21, 2009 | 03:00 PM
Ev0cRaZy's Avatar
Originally Posted by BadBoy818_818
need a punch... would u like me to help
Im not sure if you have enough common sense to even do that.
Old Feb 21, 2009 | 03:01 PM
BaLListic_EVO's Avatar
lol
Seems like this is the same guy that was asking about a clutch a while back
Old Feb 21, 2009 | 03:12 PM
Ev0cRaZy's Avatar
Originally Posted by BaLListic_EVO
lol
https://www.evolutionm.net/forums/ev...ght-quick.html
https://www.evolutionm.net/forums/ev...eal-badly.html
Old Feb 21, 2009 | 03:13 PM
detroit pistins's Avatar
and maybe if ppl wouldnt be such aholes that wouldnt give me a reason to even think of changeing my attitude
get used to the aholes around here man.
Old Feb 21, 2009 | 03:57 PM
b00sted1's Avatar
I just read through his other 2 threads...omg! What do we do with this kid?
Old Feb 22, 2009 | 12:58 AM
BadBoy818_818's Avatar
i bet u wouldn't have the b***s to say that to my face and see what happends , and jus because u knw that u would probably never see me ud talk all big and bad ***
Old Feb 22, 2009 | 01:03 AM
Originally Posted by Chabada15
your asking for help in a new thread saying that the problems are posted in another thread that you didnt even link too, thats not going to get you any help
what is the problem? and what exactly are you asking for?
the car wont idle it turns but wont idle , before the car got messed up i had a ebc and turbo timer installed , my clutch got burned and i had to wait for about a month to get it so i had the extra time and decided to take out the bov from th intake and still have it connected to the ic pipe , it worked fine for about 2 days then on the second day i was listening to some music(with the car turned off) while doing somethin else in the garage and the batterys died , so i just charged it and tryed turning on the car but i wouldnt idle , i check for any blown fuses but they were all fine , i was told here on this forum that it wouldnt start because of the bad signals the maf had recived wich i didnt even knw what that was other wise i wouldnt have messed with the bov and i was sure nothing would have happend to it but i didint knw about the maf , so im guessing thats what messed it up ive done everything ppl have suggested to do but still wont work so all im asking is what should i ask the mechanic to check or give him what kind of tip
Old Feb 22, 2009 | 01:06 AM
Originally Posted by dsmbruno
If you did that to ur stock BOV just for the noise, then light it on fire just for the laughs...
On the other note, put it back to how it was and try disconnecting ur battery for 15 seconds and see if that resets the computer. the stock computer does not run good the way u have it.
maybe its funny for u to light up an evo on fire but i dont think it is for anyone else from this forum ,ive already done the battery disconnecting and reconnecting thing a couple of times didint help , took off everything from my car and it is now 100% except for the turbo timer
Old Feb 22, 2009 | 01:11 AM
it'll help if u answer my questions
Old Feb 22, 2009 | 01:15 AM
Originally Posted by Evoardo IX
lol
He's been told already to put everything back the way it was, but nobody knows if he actually did it or not, try reading his thread about the problem, you'll see what I mean...
i noticed alot off ppl didnt understand me that i wanted to know everything what i could of done before i put everything back together and then when there wasn;t anything else left then i would try it so i wouldn't have to do alot of work , since there wasn't any other option i put everything back 2gether
Old Feb 22, 2009 | 01:46 AM
Chabada15's Avatar
try disconnecting the MAF sensor just unplug it, turn the car on and see if that helps, you must have some kind of check engine light....the car wouldnt do this without throwing a check engine light, theres a large amount of sensors that if anyone of them wasnt working correctly would produce this effect
Old Feb 22, 2009 | 01:53 AM
lol i think i havent tryed that yet , let me go down to the garage and let u knw what happend
Old Feb 22, 2009 | 01:58 AM
my batterys dead not enough to turn over the engine , i have to wait till my dad gets home to use his battery , any other ideas u have?
Old Feb 22, 2009 | 07:15 AM
Ev0cRaZy's Avatar
Sorry Sir, I forgot how badass 20yr olds are these days.
You dont need to own your car.
