Budget 2.3L Stroker Questions
Old Feb 22, 2009 | 09:59 PM
justboosted02's Avatar
Originally Posted by justa4banger
why would u buy a stroker motor for a 9 turbo?? lol
there are other things to do in an evo than just drag race
Old Feb 22, 2009 | 10:05 PM
vboy425's Avatar
Originally Posted by Tonba
^ Thank you very much!!
So an OEM Mitsu 4G64 crank eh?
Where about can I get one for a reasonable price?
I believe SPOOL rods and Eagle rods are similar if not the same. Except one is made in Australia, the other in the USA. For me, Spool rods are dirt cheap as I dont have to import them over..
Ill look into Supertech, they sound good!
Skip the Cometic? Really? How come?
wrong. Eagle rod are made in Taiwan. which is junk.
Old Feb 22, 2009 | 10:06 PM
vboy425's Avatar
yep. evo drag racing is gay and waste of a car. That's all redneck knows.
Old Feb 22, 2009 | 10:17 PM
Tonba's Avatar
^ Hmmm, its making me think twice about my Rod selection now..
Maybe AMS isnt so expensive... As long as shipping isnt so bad.
Does anyone know what the Kit comes with and how much I can pick it up for?
Old Feb 22, 2009 | 10:23 PM
evo ippo's Avatar
For the crank Tomei actually sells a 2.3 crank you can check that out
Old Feb 22, 2009 | 10:32 PM
SpeeDeviL's Avatar
search manley rods heard good things about them
Old Feb 22, 2009 | 10:36 PM
Tonba's Avatar
Does anyone have any feedback on the basic AMS stroker kit?
Old Feb 22, 2009 | 10:37 PM
what?
maybe you should reread the OP's reasons for going with a stroker
Old Feb 22, 2009 | 11:02 PM
Tonba's Avatar
Too right!
Old Feb 23, 2009 | 12:53 AM
nitroboy158's Avatar
Have you talk to Bel Garage in Sydney? You should be able to get a 4g64 crank easily in AU.
I too had to import most of my parts. But I got lucky with the exchange rate 5 months ago. The nation of left turn racing also has different fuels. Their 93 is not the same as 93 in oz.
You guys in the states are spoilt for choice with parts and free shipping etc, etc. Joys of having biggest ecomony I guess.
To give you a idea I just finished my 2.3l. Final dyno runs tomorrow. hks gt3037s kit with my 2.3 stroker and I'm getting 320kw at the wheels in 98RON.
Good luck with the build mate but seriously talk to the shops in oz that know evos. bel garage, xspeed, Rigoli Racing and don't expect much or any change from 10k AU.
Old Feb 23, 2009 | 12:57 AM
Forgot to add APC. Worlds fastest evo. Drag racing does have its place and I have a lot of respect for anyone that can build a evo with 1000+hp.
Old Feb 23, 2009 | 01:04 AM
From mitsu about $1000 AU.
^ Can you buy the 4G64 crank NEW?
If so, where from? How much?
Ive decided, I will probebly go with an OEM gasket.
Old Feb 23, 2009 | 01:26 AM
Tonba's Avatar
^ My Engine builder & tuner has been and still is IS Motor Racing.
Old Feb 23, 2009 | 02:08 AM
Tonba's Avatar
It looks like APC in Brisbane is selling a quality yet affordable kit..
Old Feb 23, 2009 | 04:26 AM
supersal's Avatar
Originally Posted by gsrboi80
-For the crank shaft just use an OEM Mitsu 4G64 crankshaft
-Eagle rods a cheap and will stand up to what your running no problem
-Springs and retainers. Supertech, Kiggley, BC, Tomei. I know BC's cost about $180
-Skip the cometic HG and just use OEM
+1
if you after a Budget 2.3L Stroker then go for the OEM 4G64 Crank
you will also need Stroker 2.3L Pistons as they are not the same as 2L Pistons
Eagle make good budget Rods and if you not aiming for +600HP I think they will be fine... Try and keep the stock rev limit 7606rpm
Its not difficult to piece togther a Budget 2.3L Stroker kit.
If you want to rev past 8000rpm then rather use your money more wisely and go built 2L with a stronger Rod and with springs & retainers and some headwork...
This is how I see it:
Stoker kit 8000rpm rev limit due to piston speeds but you can gain 500rpm in spoolup.
Built 2L rev to 9000rpm no difference in spoolup but you just gained 500rpm over the stroker.
