Budget 2.3L Stroker Questions
Old Feb 23, 2009 | 04:34 AM
  #31
D420mac's Avatar
The AMS Stroker is nice I've had mine for awhile, no problems and beat the crap out it. no reving past 8500 though.
Old Feb 23, 2009 | 07:40 AM
  #32
gsrboi80's Avatar
Noticed I mentioned Eagles being a fine rod for his build and the title of this thread is budget. I for one would only put Crower of Manley's in my car.
Old Feb 23, 2009 | 07:49 AM
  #33
cthcky5's Avatar
i no ur doing a budget build, but just remember u get what u pay for.
Old Feb 23, 2009 | 01:50 PM
  #34
Tonba's Avatar
It looks like the APC kit is definatly bang for your buck. It also is known to work. it is selling for AU$2,990.
Im also looking at getting a set of 1mm oversize valves, valve springs, Ti retainers & Head studs..
Im only really looking to rev 7,500rpm..
Old Feb 23, 2009 | 08:55 PM
  #35
Tonba's Avatar
^ How do you guys think a GT3082R with a 0.63 exhaust housing would go on a 2.3L with 272 degree cams?
Old Feb 23, 2009 | 09:35 PM
  #36
ScorpionT's Avatar
Not a good setup. The reason is you have a better breathing set of cams paired up with a decent sized compressor, and thats matched with a small turbine whee/housing. A 3076 or 3582 would work better.
As far as the budget parts go, you are better off spending the $350 more for a good set of Manley I beams rather than going with the cheap Eagles. You are probably going to sink $6k+ with what you want to do, so why skimp on something that could make or break your setup?
  #37
D420mac's Avatar
I heve to agree, it's better to save and get the better parts! Buying the cheaper parts and then having to buy the quality parts, costs more!.
I did the same thing when buying my gauges, I've spent an additional $600?, buying quality ones, in addition to the cheaper ones.
Old Feb 23, 2009 | 09:39 PM
  #38
justa4banger's Avatar
get a hta35r for real man power
Old Feb 23, 2009 | 09:40 PM
  #39
Tonba's Avatar
So what about the GT3076R with a 0.82 Rear housing? Will that be laggy?
I would like to try and get 22~25psi at 3800RPM.
Old Feb 23, 2009 | 09:42 PM
  #40
Tonba's Avatar
Too much $$, too much lagg, and Im also not really interested in the big *** power figure..
Old Feb 24, 2009 | 12:28 AM
  #41
supersal's Avatar
If your on a budget and are not looking for much more than 450HP why not go for a built 2L:
- Arrow Rods
- CP Pistons
and the new Tomei ARMS Turbo or the RED
272 Kelfords and some headwork + springs and retainers
Will be much better bang for the buck at the end of the day
Old Feb 24, 2009 | 12:05 PM
  #42
ScorpionT's Avatar
That would be a fine choice. You could even go .63 for better spool if you really wanted. I would stick with .82, but I like more top end grunt.
Old Feb 24, 2009 | 12:29 PM
  #43
Tonba's Avatar
See, Im looking for full boost at 3800 ~ 4000rpm, without it falling over at the top. Im afraid the 0.63 will fall over..
Why is it that you think the 0.63 would be fine on a 3076R but not on a GT3082R?
Old Feb 24, 2009 | 03:44 PM
  #44
ScorpionT's Avatar
The 3082 has a larger compressor that would be choked out and not be in the efficiency range with that small turbine side. Compressor is basically too big for the turbine.
Old Feb 24, 2009 | 04:02 PM
  #45
Tonba's Avatar
If I went to the GT3082R but threw a 0.82 housing on it, how laggy would it be?
As I said, im looking for quick spool, but I dont want it falling over up top...
