Boost Drifting Bad
Old Feb 25, 2009 | 04:07 AM
SuperchargedGTZ's Avatar
Boost Drifting Bad
this morning while passing a truck on rt 34 in ct, i noticed at WOT my boost is all of sudden drifting to 25 (could be drifting higher as I shut it down when I saw that).
Mods
TB exhaust (UR with test pipe)
hks 272
660cc inj
FP Green
buschur FMIC and upper piping
buschur intake
hallam in cockpit boost controller
Defi boost gauge
ported exhaust mani
ss 02 housing
Forge DV
few more mods but nothing that would affect boost
now i just had my clutch swapped out and i aslo changed the vacuum tubing for the DV with a potentially larger inner diameter than the rest of the vacuum lines to the wastegate.
Thanks in advance for the help
Old Feb 25, 2009 | 05:09 AM
sparky's Avatar
Could be colder weather causing the increase. What was your boost set at, and how cold is it out there?
Old Feb 25, 2009 | 05:48 AM
stryfetew's Avatar
check vacuum lines
Old Feb 25, 2009 | 06:27 AM
Stew's Avatar
Ported ex mani and O2 causing a bit of boost creep mayhaps?
Old Feb 25, 2009 | 07:21 AM
zeus1's Avatar
hi i have a pretty similar set up to you. cold weather caused this on my car. were you downshifting or in a higher gear where you were loading the car.
Old Feb 25, 2009 | 07:28 AM
joseph k's Avatar
hmm ok i was thinking this had something to do with drifting not boost creep... either way it is possible that it is the vacuum lines, but not due to the larger diameter. i would lean more towards the weather and ported ex mani like said above
Old Feb 25, 2009 | 08:01 AM
i have had these mods for almost 2.5 years.
the colder weather has caused me to lower the boost but i have never seen this dramatic of an increase.
spoke to Jimmy at THESHOP. gonna strap it to the dyno and check it with another boost gauge to rule that out. after that, I was thinking maybe the wastegate??
Old Feb 25, 2009 | 09:25 AM
cthcky5's Avatar
the car is boost creeping. probly do to the colder weather. colder the weather= denser air. this can be due to the manifold being ported and the o2 housing. wouldnt hurt to check ur vaccum lines either. my buddys old evo boost creeped only when it was cold out. went it was warmer out problem was solved. he also had a megan o2 housing.
Old Feb 26, 2009 | 04:32 AM
i understand the whole colder air = denser air concept....however, what I am saying is I have NEVER ever seen this before. The hallam mbc has been great (4+years)...and now this.
anyways, I am going to bring it theshop and Jimmy is gonna look at it on saturday.
I will post the results
thanks
Old Feb 26, 2009 | 04:38 AM
Sharkbite2000's Avatar
AEM electonic boost never had a problem with boost creep it keeps the boot in check.
Old Feb 26, 2009 | 04:48 AM
sparky's Avatar
You have time to look over at your boost gauge to check for creep while you're travelling along at 320 KPH? JK
Old Feb 26, 2009 | 10:13 AM
Typically its a rare occasion, but for some reason or another I looked over and i was like so i shut her down
I will see on sat. bringing to dyno
Old Feb 26, 2009 | 10:39 AM
heel2toe's Avatar
You have had your MBC for 4 years now you said? Maybe it needs to be taken apart and rebuilt? Either that or its the cold weather and it needs to be adjusted a tad.
adotwhite
Aug 12, 2017 05:45 AM
Viegasjuice
Apr 16, 2013 01:50 PM
stryfetew
17
Aug 20, 2010 06:15 AM
Anyevowilldo
Nov 11, 2008 01:39 PM
IceEvoIV
25
Apr 10, 2006 11:01 AM
