top mount vs equal length vs cast manifolds
Old Feb 25, 2009 | 03:08 PM
booster9's Avatar
ok, so ive been trying to find something on top mount manifolds.. i have an equal length now. and was just wondering if top mount will help increase spool.
so far in my search everyone has only said topmount increases HP but no one says anything about spool.
reasons??
are there any know it alls out there that might be able to enlighten me what the advantages and disadvantages of the different manifolds?
Old Feb 25, 2009 | 04:23 PM
a1091156's Avatar
http://www.sae.org/technical/papers/2005-01-3812
It's $15 if you want the truth.
But if you want an unscientific opinion on the matter.......
Old Feb 25, 2009 | 05:29 PM
03volkevo8's Avatar
Also wanting to know the difference.
Old Feb 25, 2009 | 10:48 PM
Ted B's Avatar
I don't know if a genuine 'know-it-all' is really necessary, since the basic strategies are fairly easy to comprehend.
- Shorter primaries are better because they lose the least amount of heat and exhaust pulse energy between the head and turbo.'
- Primaries of relatively equal length are better because they space exhaust pulse 'hits' on the turbine wheel more evenly.
- Cast manifolds are good in that they retain the most heat, but seldomly can they be made to ideal proportions without being unweildly and heavy.
- Short radius turns in the primaries negatively impact pulse energy. Larger, more gentle turns are best, but not always possible due to spatial constraints.
Ideally, one wants a manifold that gives the shortest possible, relatively equal length runners without resorting to short radius bends to do it. With an EVO, the factory turbo placement requires short radius bends to make it work, so there is some compromise there. A manifold with slightly longer primaries but with fewer turns probably represents the best compromise, although it places the turbo in a different location.
Old Feb 26, 2009 | 10:38 AM
C6C6CH3vo's Avatar
Here a good pdf beyond everyones head, reading will make your eye's bleed. But it's free.
1)
"Numerical computations of the unsteady flow in a radial turbine"
http://www.diva-portal.org/diva/getD...__fulltext.pdf
2)
You'll have to search this one out but it's definately worthwhile to read (math is overwhelming throughout though):
"Application of Turbochargers in Spark Ignition Passenger Vehicles"
a thesis presented at Stellenbosch University by Wallace William Bester
enjoy
Old Feb 26, 2009 | 07:02 PM
a1091156's Avatar
I thought you knew better Ted.... air is the best insulator there is and cast-iron the worse out of the possible alternatives. So realistically a thin walled 304 (cheap) or inconel (expensive but better) manifold is the name of the game.
Having a thick walled cast-iron manifold just means it can absorb more of the exhaust energy not less..
Old Feb 26, 2009 | 08:25 PM
Ted B's Avatar
Originally Posted by a1091156
I thought you knew better Ted....Having a thick walled cast-iron manifold just means it can absorb more of the exhaust energy not less..
That's exactly right. Cast iron absorbs it and retains it, and that makes it better. Ever wonder why tubular steel manifolds radiate so much more heat than a cast iron manifold? Radiated heat is wasted energy. This isn't my opinion. It's common knowledge. Think about it.
Old Feb 27, 2009 | 12:00 AM
DIDYSIS's Avatar
Bucshur said there Cast was great with the HTA kit. That's what I am going with.
Old Feb 27, 2009 | 10:26 AM
JKav's Avatar
All true, except retaining heat is no bueno. The higher thermal mass of cast manifolds tends to rob exhaust energy when you want it most, and increases heat soakback.
There are other reasons cast manifolds are nice, but heat retention is not one of them.
Also I'd add that modern OEM cast manifolds are not cast iron but high nickel steel or austenitic stainless.
Old Feb 27, 2009 | 10:41 AM
PVD04's Avatar
Once the cast manifold has been heated, it will no longer be absorbing energy from the exhaust gases. All of the energy is going into spinning the turbine. With a tubular manifold a significant amount of thermal energy is radiating out to the air, reducing the energy of the air prior to reaching the turbine. While the cast manifold may absorb more energy shortly after startup, it will help the exhaust gas retain energy after it has warmed.
Old Feb 27, 2009 | 10:46 AM
Ted B's Avatar
PVD04 is correct.
Old Feb 27, 2009 | 11:02 AM
BerserkerX's Avatar
Where would you find and inconel manifold? That sounds like a it would cost a pretty penny. From what I understand about inconel (other than it being expensive since I work in a machine shop) doesn't it also resist build up and what not on it? I have heard that it doesn't let oils and other residue stick to it once it is heated.
With othe manifolds other than cast how much does a coating help to keep the heat in and not radiating to the outside of the car? Could you technically coat a stock one and have it do well?
Old Feb 27, 2009 | 11:07 AM
donbrown34567's Avatar
Originally Posted by BerserkerX
With manifolds other than cast how much does a coating help to keep the heat in and not radiating to the outside of the car? Could you technically coat a stock one and have it do well?
+1 to that, I have the same question.
Don
Old Feb 27, 2009 | 11:45 AM
Ev0ikon's Avatar
^+1
How about a coated tubular AND wrapped?
Old Feb 27, 2009 | 12:38 PM
justboosted02's Avatar
1)
2)
enjoy
awesome read
