White rabbit need help
Old Mar 4, 2009 | 11:06 PM
SpoolnupTuning's Avatar
Originally Posted by AznDragonV
FP also made a WR9 turbo with the evo 9 compressor...
correct seeing that their is 2 maybe more in nc!
Old Mar 5, 2009 | 06:44 AM
Zeus's Avatar
Compressor cover... still the exact same billet compressor wheel.
Old Mar 5, 2009 | 06:57 AM
spooln2004's Avatar
talk to cbrd they will help you out
Old Mar 5, 2009 | 07:34 PM
abazaba410's Avatar
so evo9 turbo or WR? I was thinking of going to green but I got 80k miles and dont wanna f **** up more than it already is (transfer case, clutch). Lookin to get about 450 awhp on e85.
Old Mar 9, 2009 | 09:10 AM
jrmav32's Avatar
so i took of the oil cap to check my oil and the oil was milky looks bad and i had just changed the oil on it do yall still think it can be my turbo
Old Mar 14, 2009 | 11:35 PM
J8dailo's Avatar
what about the BR 20g with the 5 blade instead the old 6 blade design? does that have compressor surge problems...havent heard much about that turbo anymore..
Old Mar 15, 2009 | 05:29 AM
sparky's Avatar
You are going back a few generations, so the exact nomenclature has become a bit nebulous in my mind. There have been so many 20G aftermarket variations and upgrades and different names for the same, or very similar FP turbos. But I'll give it my best shot.
I think that the latest iteration is the BR 20G-LT, which is the same turbo as the Forced Performance EvoGreen. There were a couple of earlier versions however. There was the BR 20G-8-5, which used the VIII compressor housing. This is the one that had surge issues, I think. The BR 20G-9-5 was the successful upgrade of the earlier BR 20G-8-5, configured with the IX compressor housing. This last one apparently cured the surge problem.
Incidentally, the BR 20G-8-5 was very similar to the WR-8. They both used the 5-bladed FP White Rabbit compressor wheel. The only difference was in the turbine wheels. The White Rabbits(WR-8, & WR-9) both used the TiAl turbine wheels from the TME, or JDM RS, while the BR 20G's used standard Inconel turbine wheels.
nabilsx
16
Jan 26, 2010 05:07 PM
dsm25psi
25
Oct 31, 2007 08:13 PM
IVERSON3270
15
Jun 1, 2007 12:40 PM
Evolution8Blue
37
May 4, 2006 06:57 PM
