smoke coming from exhaust
Old May 21, 2009 | 04:19 PM
  #31
jrmav32's Avatar
o ok but what about the oil looking milky it looks like i have water in the oil what can be the cause of that?
Old May 21, 2009 | 05:41 PM
  #32
ev0lution9's Avatar
id say its the seals on the turbos that are bad have you checked them? what color is the smoke?
Old May 22, 2009 | 03:47 PM
  #33
jrmav32's Avatar
white with a little of blue when i turn it off it looks like steam coming of from the exhaust
Old May 22, 2009 | 04:40 PM
  #34
barneyb's Avatar
There are no seals on the turbo that will allow coolant to get into the oil. The only way coolant could get to the oil by way of the turbo is if the center section cracked and I've never heard of that happening.
Old May 22, 2009 | 04:51 PM
  #35
borievoinitialD's Avatar
i think the turbo is going, had the same smoke on idle on mine when i blew the seals on my old t3/t4 on my turbo integra...
Old May 22, 2009 | 04:58 PM
  #36
ev0lution9's Avatar
i wasnt sure of the color of the smoke til now...it was just a guess...it could also be your headgasket on its way out since the smoke is white
Old May 24, 2009 | 11:04 AM
  #37
ev0lution9's Avatar
Originally Posted by choturbo
ill say seals on the turbo.
thats what i said..
Old Oct 21, 2009 | 11:27 PM
  #38
jrmav32's Avatar
what about my valve seals? intake and exhaust?
Old Oct 22, 2009 | 01:05 AM
  #39
huevosrancheros's Avatar
check PCV valve
Pull turbo out and check shaft play
Do a compression test
Get headgasket checked(if your oil is milky, it more than likely to be a blown head gasket or your piston rings going bad)
Do the cheapest stuff first then work your way down to the wallet crackers.
Old Oct 22, 2009 | 08:16 AM
  #40
oxyigen's Avatar
color of smokie is important..
Old Oct 22, 2009 | 08:26 AM
  #41
xsolowx's Avatar
i was getting white smoke when i would get spooled up...turned out the hose on the catch can was pinched under the strut bar.....it was also causing my oil cap to leak from the pressure...
Old Oct 22, 2009 | 11:01 AM
  #42
jrmav32's Avatar
well the smoke is bluish/white smoke and it doesnt stop when it idles or while im driving it.. the oil cap looks brownish so theres water in my block.. pistons are good got them replaced 50 miles ago, and the head gaskets.. my car doesnt have a pcv valve though i bought it like that from the previous owner... oil pressure is low but when im driving it it goes back to normal. Turbo looks good..
Old Oct 22, 2009 | 11:13 AM
  #43
TTP Engineering's Avatar
What does the oil cap have to do with water in your block? Of course there is water in your block, its a water cooled engine.
Just because your pistons were replaced, does not mean they were installed correctly, the rings were oriented correctly, the ring end gaps were set correctly, the cylinders were straight, the crosshatching and honing was done correctly.
The evo has a head gasket, not gaskets. It's not a V8.
If you do not have a PCV valve, then the boost will either blow oil into your intake or if there are no hoses on the valvecover then crankcase presure will build up until it blows through the valveseals into your cylinders.
Old Oct 22, 2009 | 06:26 PM
  #44
jrmav32's Avatar
well the oil looks milky whitish brownish, so theres water sipping through somewhere either my head is craked or head gasket blew again. cause thats too much condensation on the oil cap and on the dip stick looking that
and i have no hoses on the valve cover..
also the oil pressure is low but when im driving it it goes back to normal. but when i stop it goes down.
Old Oct 22, 2009 | 06:30 PM
  #45
3gEclipseTurbo's Avatar
do a compression test its either:
valve seals
head gasket
piston rings
turbo seals
if your compression is good then its the turbo. If not then my moneys on the valve seals
