Question on stock air box modding
Old Mar 19, 2009 | 10:56 PM
EvoTio's Avatar
Originally Posted by Evoardo IX
Thanks a lot, I saw your box on lancerregister, the guys over there love your setup and you know what, I might want to try it, you mind sharing with us a little more detail as to what filter, bracket, etc etc you used? I was thinking with your setup you could aditionally add a duct/pipe to get some air from the front bumper (right around where the horn is on the left) and send a straight charge of cold air to that side of the box. I bet your setup makes the turbo/DV even louder
No problem. I could pm you the filter specs if you want.
Old Mar 19, 2009 | 10:59 PM
Evoardo IX's Avatar
Please do, if you have more pics you can send them too. What is the metal thing holding the filter on the side? is the turbo louder with your mod?
Ed
Old Mar 19, 2009 | 11:08 PM
06MREvo's Avatar
Originally Posted by Boltz.
I like this mod better
your air filter looks pretty big in the first pic & doesn't look like it would fit right in the 1st pic but looks fine in the 2nd...did you just cut the bottom of the air box off??
Originally Posted by BluEVOIX
The ultimate stock air box modification by MalibuJack:
https://www.evolutionm.net/forums/ev...irbox-mod.html
I had this setup forever and worked well with the small K&N filter and Maf adapter kit from AMS...but now that i have the JMF intake tube I can't use the modified airbox anymore...
Old Mar 20, 2009 | 04:13 AM
racer135's Avatar
Don't PM just post them here so everyone can see them. I think this is a very nice approach.
Old Mar 20, 2009 | 07:28 PM
EvoTio's Avatar
Lol, ok. I got my inspiration for this set up from a couple of guys on the NorCalEvo.net forums. Here's the thread: http://www.norcalevo.net/showthread.php?t=26813. It'll tell you pretty much how to build your own stealth stock air box. I made mine using a K & N filter for a Briggs & Stratton engine (part # 33-2238). It cost me about 20 bucks and a weekend of my time. I modified a MAF bracket from a 3rd gen Supra to fit the filter. I also applied some RTV to make sure the filter sealed nicely. It acts like a poor man's ARC box. It'll definitely make your diverter valve sound much louder. I like a very stock looking engine compartment and this stealth air box mod definitely helps keep me looking stock while still having a good flowing intake.
Old Mar 20, 2009 | 07:30 PM
EvoTio's Avatar
Originally Posted by sparky
Nice big-breathing, camoulflaged box, EvoTio. A+ for ingenuity. I like it............
Thanks man.
Old Mar 22, 2009 | 10:43 AM
racer135's Avatar
Evoardo IX, very nice way you modified your stock air box. The cutting of the box and the wire mesh are very cleanly done.
Here's my take on my stock air box. I modified my air box to accept a second K & N filter on the side. That filter gets a straight shot of air into the MAF. I also have a drop in K & N in the stock location. This mod allows me to maintain 24 psi until redline with my FP White. Once the box is bolted back in the engine compartment, everything looks completely stock.
I am was looking into me engine to make this airbox mod and notice that in order to maek the small filter fit you have to cut and remove the airbox holder on the side of the box. Is the stock airbox still solid in plance with this holder removed. I suppose you kept the steel bracket and just cut the plastic holder on the airbos side wehre the filter is placed.
Old Mar 22, 2009 | 11:35 AM
EvoTio's Avatar
Yes, you do have to cut away the side tab that secures the box on the drivers side. The box does move some but it's still secure with the other front tab bolted down and the MAF accordian tube holds it in place also. I'm going to go back and make up a metal tab one of these days to attach to the box and the drivers side mounting point. Then I'll be completely satisfied with the way the box is mounted.
Old Mar 22, 2009 | 07:51 PM
dsevo's Avatar
Has anyone ever tried to run a big turbo on the stock box? I'd be curious to know if the stock air box can be made to flow as much as the MAF will flow, meaning that the MAF becomes the restriction. I'd like to keep the stock computer on my build, so I am going to try to run the stock box up to 600+ whp. Anyone ran a stock box at these levels?
Old Mar 22, 2009 | 08:21 PM
Jeff_Jeske's Avatar
I'm not sure why you wouldn't want to keep it sealed. As soon as you leave the line the stock box is getting force fed cool air from the high pressure intake on the front of the car.
Why would you want to suck in hot air from the hot engine bay.
I'm sure some of these hax show gains on a dyno because the car isn't moving and odds are the passes are made with the hood open but **** pound your car for a bit then pop the hood and feel the heat. The intake is right behind the radiator and right next to the exhaust manifold.
Unless you are putting down 400whp I highly doubt that the stock air box with drop in is a restriction at speed.
Old Mar 22, 2009 | 09:33 PM
evoIXcencal83's Avatar
Hey, yeah I remember. Nice to have met you. BTW, my turbo failed on my last run that I made and had to limp home back to L.A .
was the failure due to oil starvation?
kevinlubitski
Mar 15, 2012 12:58 PM
4g63girl
Oct 29, 2011 02:25 PM
HornstarBU
Lancer How Tos / Installations
Apr 15, 2011 07:41 AM
EmeryatSTM
Oct 26, 2009 02:42 PM
mitsuorder
20
Mar 19, 2004 12:29 PM
