clutch job need help!!
Old Mar 9, 2009 | 08:57 AM
  #31
BaLListic_EVO's Avatar
i knew a guy with an ACT that did it with 2000+ miles. I believe its just one of those deals. It will do it sometimes and not others. I would drive it to break in then give it a real nasty launch and see if some heat makes the issue go away.
Old Mar 9, 2009 | 09:00 AM
  #32
Malik_EvoIX's Avatar
i got about 300 miles on it shifts great. i will launch it as soon as it hits 500 miles
Old Mar 9, 2009 | 09:13 AM
  #33
depending on the amount of city driving you do you may require more miles. If you just do alot of highway miles the clutch will never go thru its heat cycles as intended for break in.
Old Mar 9, 2009 | 01:32 PM
  #34
i drive alot i actually launched the car this afternoon properly and damn it holds great. and still makes the noise.
Old Mar 9, 2009 | 07:02 PM
  #35
happened again this time my neighbors were jogging and they were "startled"
Old Mar 9, 2009 | 08:10 PM
  #36
05EvoVIII's Avatar
dude just fill the tank up...go drive around till u get 500 miles on the clutch then go launch the thing n be nasty with it.....Show it who wears the pants in the relationship!
Old Mar 10, 2009 | 09:03 AM
  #37
michigan weather sucks it's been raining here deep so far today
Old Mar 11, 2009 | 02:13 AM
  #38
forgot to mention also when i downshift to 1st gear (instead of using breaks) same thing happens
Old Mar 11, 2009 | 07:04 AM
  #39
i am going to go on a 150 mile trip today so far i got 320 miles on it bump
Old Mar 11, 2009 | 10:25 AM
  #40
ever clutch with a ceramic based material i have ever heard makes this noise from a stop... i would chalk it up as normal and forget about it...btw does it sound like nails on a chalkboard? And honestly there isnt that much you can screw up when doing a clutch job. I have done 6-7 of them and never had any issues. Only issues i have ever experience was a blown axle seal due to a shops ****ty repair on a t-case.
forgot to mention it does sound like nails on chalkboard.
Old Mar 11, 2009 | 10:54 AM
  #41
MitsuJoe's Avatar
Is the noise during decel only?
Old Mar 11, 2009 | 02:01 PM
  #42
happens when takeoff from a stop. when car is in motion it's fine no noise whifts great trough gears
Old Mar 11, 2009 | 06:31 PM
  #43
bump
Old Mar 12, 2009 | 08:13 AM
  #44
bump
Old Mar 12, 2009 | 08:26 AM
  #45
MitsuJoe's Avatar
Does it sound like this does it?
http://www.youtube.com/watch?v=ytdPMX-Lv0s
