clutch job need help!!
Old Mar 12, 2009 | 08:45 AM
  #46
mhgsx's Avatar
My brother's Exedy twin HD makes a loud "honk" noise when you slip the clutch in 1st when the clutch is hot from stop-and-go driving. It's just the way the material is. You said it yourself that it doesn't make any noise if you quickly slip or launch the car.
I say, get used to the noise or learn/avoid situations that require a nice clutch slip to take off gently.
Old Mar 12, 2009 | 09:34 AM
  #47
Evo1001's Avatar
If the noise happens when you put it into 1st (with clutch pushed in) then you prob need to adjust your clutch up higher. Is it easy or hard to put it in 1st gear?
If the elephant noise (lol) - happens when you release the clutch, then I would wait a little more for the new clutch to adjust to the flywheel. I'm curious, how loud is it?
Old Mar 12, 2009 | 09:43 AM
  #48
mhgsx's Avatar
Besides the noise, can give us your impressions for this clutch?
How's the clutch pedal stiffness compared to the stock clutch? Does the clutch engage close to the floor or near the top of the pedal stroke?
Old Mar 12, 2009 | 12:06 PM
  #49
Malik_EvoIX's Avatar
it's a little similar stiffness to act mb7hdss and the adjustment is top of the pedal not low. it shifts great trough the gears.
  #50
lol you were there when my car was done he adjusted the pedal to a certain point.
Old Mar 12, 2009 | 12:08 PM
  #51
Originally Posted by MitsuJoe
Does it sound like this does it?
http://www.youtube.com/watch?v=ytdPMX-Lv0s
the noise is similar to that not exactly...... happens only during takeoff and when downshifting to 1st gear. i will try to upload video i don't have camera phone
Old Mar 12, 2009 | 12:17 PM
  #52
BoostINurI's Avatar
Damn guys....it's the disc or discs slipping a lil bit when being engaged....just building some heat no biggie. My car does this also when feathering the clutch. Welcome to having a manly clutch.
Old Mar 12, 2009 | 12:19 PM
  #53
if i would of known i would bought a different clutch its annoying noise did your noise go away?
Old Mar 12, 2009 | 03:21 PM
  #54
Evo1001's Avatar
I didn't hear any weird clutch noises that night. wait a lil more and see what happens. If it doesn't go away or gets worse after the break-in period, take it back to the shop and have the guy open it up. Call manufacturer and ask them if this might be normal during break-in period (I doubt it). Good luck.
Old Mar 12, 2009 | 09:03 PM
  #55
thanks ^^
Old Mar 12, 2009 | 09:08 PM
  #56
TTP Engineering's Avatar
Its a cerametallic disc and usually that sound is attributed to unsprung disc clutches which are a no no for the evo.
Old Mar 12, 2009 | 09:11 PM
  #57
uh? no no for evos?
Old Mar 13, 2009 | 02:25 PM
  #58
*Finally got the video clips*
http://videos.streetfire.net/video/I...ice_640909.htm
http://videos.streetfire.net/video/E...ise_640908.htm
Old Mar 13, 2009 | 03:00 PM
  #59
Bump`
Old Mar 13, 2009 | 03:41 PM
  #60
bumpy
