PiPlease help.!!
Please help.!!
Picked my car up from the shop last night. Had the TC rebuilt and a clutch and flywheel installed. My problem is while I'm driving when I go to shift my boost would usually flutter. So everything was fine driving home. I stopped at a friends house turned off the car for about 20mins then got back in and continued home, idk what happened in 20 mins but on my drive home when I would shift the boost would just plane off. I have a greddy POS recirc bov I've hated it since day one! I popped the hood and took a peek and everything is properly connected. does anyone thing there's a problem with the spring on the bov.?
Ok say I'm driving second gear kinda heavy on the throttle.. and I let off the gas completely I would get a flutter through the intake. Now boost doesn't come on as strong and when I back off the throttlei get no flutter through the intake. Newbie guys sry for not using correct termanology. Mabye I can take a quick video. Its gotta be my bov, intake, or a vacuum line I assume.
Well the bov was stuck open.. strange but with a lil tlc it is back to normal. Took the time to install my shifter base bushings last night.. what a difference from stock.!
Your turbo must have spun to near death to get that much boost since the greddy was stuck onpe!
You think I caused any damage? It drives great now just like before but I'm still not able to bring up to full boost cuz of the fresh clutch.!
I have the same problem of not being able to quickly build boost. I get the flutter if I try to floor it. Only thing I did was take me UIC pipe off and install cams. I hope its just a leak and not my BOV.
Teal2nnr
Feb 25, 2017 10:55 PM
tsidrift1
63
Oct 9, 2016 02:26 AM
et98cav
Mar 7, 2016 02:22 PM
