Any ideas on where to look next? Bucking, Stalling
Old May 24, 2012 | 12:32 PM
tsidrift1's Avatar
So lately, every once in a while, I will just be cruising along and I will get a hard bucking. This isnt under boost or anything. This is just cruising. When it would do it, it would just do it a few times, then I would never experience any problems. Today, I was cruising and same thing. It started bucking, but a little harder this time and more. I though nothing of it, it will go away and all will be good. Well, the first stoplight that I hit, it dies. I immediately fire it right back up and try to go, it dies again. Now it won start. Just cranks and cranks. It did fire up once and then just sputtered really bad and died. I get out, check everything under the hood that I can at a quick glance. Nothing out of the ordinary. Finally after almost 20min of just snooping around it starts up again. By this time I am pissed that I have been out in the middle of the road, so I put it in gear and just smash the gas. 1,2,3,4 gear pull WOT, no issues. I drive the 15 min drive back home, no issues.
I am getting ready to check plugs, but what else can I look at here? Ideas? Scanned for check engine codes and got none.
Old May 24, 2012 | 01:10 PM
tsidrift1's Avatar
plugs look fine
Old May 24, 2012 | 01:20 PM
BluEVOIX's Avatar
Any CEL at the time? Maybe the Cam sensor is going bad ?
Old May 24, 2012 | 01:53 PM
CurseDSM's Avatar
Just out of wonderment did your afr go real lean? I have had this happen once and a while and my afr goes real lean. Then out of no where it goes away. Car runs flawless after that.
Old May 24, 2012 | 02:06 PM
tsidrift1's Avatar
No CEL's of course. I just went for another drive and its bad. Car bucks very hard. It cutout once real bad and I just floored the gas for a good 3 seconds and got no response from the car at all. I logged that small drive where it bucked pretty bad, sent it to Tom just for safe measure. I dont knwo what went wrong. A week ago I could say nothing but great things about the car, now I cant even drive it without it bucking violently on me.
Then to add to it. I have already payed for a hotel down in St. louis, cause I was gonna go to the track down there tomorrow night. Looks like theres a $90 wasted!
Old May 24, 2012 | 02:13 PM
tsidrift1's Avatar
The only thing I can think of, is it might be the cam sensor. Being as I have an ams tubular mani. Picked a hell of a day to go out if thats whats it. I have a Buschur cam sensor sheild on the ups truck for delivery today!
Old May 24, 2012 | 02:32 PM
Spec-Ops1's Avatar
Try swapping in the stock coil packs... possibly overheating one of the toyota coils...
Old May 24, 2012 | 03:14 PM
tsidrift1's Avatar
Cam sensor made no changes
Old May 24, 2012 | 04:46 PM
CurseDSM's Avatar
Good luck with it. Hopefully it will solve the prob
Old May 25, 2012 | 01:32 PM
tsidrift1's Avatar
Welp, no issues yesterday, but today I go for a drive and it started again. Hasnt died on me, but its bucked a couple times cruising. PLugs are like new, replaced cam position sensor.
Old May 26, 2012 | 03:00 PM
tsidrift1's Avatar
Gonna swap my spoolinup with a buddies sparktech cop and see if that fixes it.
Old May 26, 2012 | 04:47 PM
tsidrift1's Avatar
Deos anyone know if there are any major differences in the mivec cam angle sensor and the exhaust cam angle sensor? I know there is different part numbers and the mivec one is like $30 more than the exhaust one. I didnt know if there were truly any difference or if its just a way mitsu makes more money haha.
Old May 26, 2012 | 08:25 PM
tsidrift1's Avatar
So I hooked up evoscan hoping to see a code stored in the ecu. There are no cel's, but FINALLY!! I got a code stored. P0123. Throttle Position Sensor. At least I have a starting point now!
Old May 26, 2012 | 08:32 PM
jason42003's Avatar
is yours doing this after shifting, more specifically after the shift from 1st to 2nd.
Old May 26, 2012 | 08:42 PM
OverBoostedEvo's Avatar
i see u threw the throttle position sensor code, thats what i was going to say to check its either not plugged in all the way or is going bad. when i had my plug lose i could just barely hit the pedal and it be fine (but would take forever to get up to speed haha) or if i went full throttle it be fine, but would buck like crazy inbetween. then i just happen to push on the plug and it snapped back in and the issue went away and never came back
