Any ideas on where to look next? Bucking, Stalling
Old Nov 6, 2014 | 11:06 PM
  #61
frequency25's Avatar
Originally Posted by tsidrift1
So I hooked up evoscan hoping to see a code stored in the ecu. There are no cel's, but FINALLY!! I got a code stored. P0123. Throttle Position Sensor. At least I have a starting point now!
hey did you ever figure out the bucking and stalling issue? i am having the same issue and is ticking me off.. was yours coolant temp
Old Nov 7, 2014 | 02:45 PM
  #62
evoIV96's Avatar
Hey, I finally got my problem sorted out by changing the ht leads(spark plug leads) and coils packs.got them of a evo 9 engine because they are all the same.if you arnt sure change your spark plugs or clean them.go for a drive when its bucking ,take out your spark plugs and they should be all the same.If one is kinda white it means the fuel hasnt properly burned without a proper spark in that cylinder or at least that is the theory.
Old Nov 8, 2014 | 09:46 AM
  #63
thanks i'll try that next.. i have a COP setup on the way I will give that a shot as well .
Old Oct 9, 2016 | 02:26 AM
  #64
jr_2006IXMR's Avatar
I remember replacing the coolant temp sensor and I never had any issue again with this. Sounds funny, but its what worked.
going to give this a shot
awdordie
Jun 15, 2017 10:00 AM
evo.matt
May 20, 2017 09:01 PM
Eartears
23
Mar 1, 2017 11:53 AM
MikeyT
Nov 7, 2016 02:18 AM
