shifting gears
Old Mar 11, 2009 | 04:59 PM
sevy2213's Avatar
shifting gears
hey....ok so i have a IX with just less than 20,000 miles on it and sometimes when i am shiftin from 1st to 2nd and 2nd to 3rd under 3000 rpms i have trouble getting it into gear. if i be realy really nice with it i an can get in to go into next gear smoth but just normal shifting it sticks and once in awhile grinds so i think somthing could/is wrong.......does anyone have an idea what to do bout it ?
thanks
Old Mar 11, 2009 | 05:04 PM
MR_Lance's Avatar
pretty common problem with the MR. your synchros are going. if you are under warranty you can get them replaced most likely. my car does the same thing, it shifts ok sometimes, but i get locked out of a gear onec in a while and the rest of my shifts are usually pretty notchy.
Old Mar 11, 2009 | 05:30 PM
Kracka's Avatar
Before assuming your synchros are going bad replace the fluid. Also, does it only happen when its really cold outside?
Old Mar 11, 2009 | 05:35 PM
apagan01's Avatar
get the tranny up to operating temp and then figure out if you still get locked out and if you still have the heavy notchy gears.
i usto get locked out on 5th anything above 4k rpm's
get a good oil in there also will help
Old Mar 11, 2009 | 05:41 PM
sevy2213's Avatar
thanks.....yea it def does it when its cold but even after i have been driving the car for awhile it still does. i just wanna know if i gotta take it to the dealership and get it looked at or its a known common problem before i start modin the car. i didnt really notice the problem over the summer
Old Mar 11, 2009 | 05:54 PM
porsherules911's Avatar
this is a known problem especially for 6spd owners. When my car is cold, I don't even bother trying to shift into 2nd and just skip to third. It will be notchy as hell and grind if I have to put it into 2nd. But once I get on the highway or drive for a while, the tranny will shift like butter, even 2nd gear. I was worried at first about the 2nd gear notchiness but everyone I've talked to confirmed that they have the same issue and its pretty much normal. I've also found that shifting quickly to 2nd at low rpms will go in smoother than other times so you can try that too.
Old Mar 11, 2009 | 07:50 PM
MR_Lance's Avatar
guess I should have said that. check the fluids first, and if after replacing the fluids you still have a problem it's probably the synchros. Most people just kinda live with it, some get it replaced. I had my changed the fluids during my 30k service and the transmission really didnt feel any different before or after. shifts were still notchy every once in a while, but could be super smooth 2 minutes later. weird.
Old Mar 13, 2009 | 05:23 AM
sevy2213's Avatar
ok....i got an apointment to drop it off at the dealership on monday cuz its still under warranty and no mods on the car yet so ill let them fix it so i dont have to spend money. ill let you guys know what they say and if they fix it or not
thanks
Old Mar 13, 2009 | 06:29 AM
monkey_187's Avatar
I think it is your synchros cause I am having the same problem right now, mine is getting fixed as we speak.
Old Mar 16, 2009 | 05:04 PM
sevy2213's Avatar
well i just got my car back and they said nothing is wrong with it. it was test driven and check for tranny leaks but didnt have problem driving/shifting and no leaks. so ill just see what happens with the warm weather comin so it might have been the real cold temps up here.
monkey...what did you tell them was wrong with ur car and how many miles are on it?
Old Mar 25, 2009 | 03:08 PM
dgrumpys's Avatar
Grinds
ok, so someone said that there car is getting there synchros redone at the dealer?
if so please post back and tell us if its fixed. also how easily was the dealer willing to do this repair? how long did it take them to "diagnose"? how long was the car at the shop?
im asking cause my evo8 is shiftin like **** and i have to feather the clutch in any up shift..... the same way you do a 1- 2.......... its driving me nuts. I have changed out the tranny fluid with oem and its still like crap until the trans heats up "20 min" and even then any shift over 4000 grinds....
thanks
Old Mar 25, 2009 | 05:47 PM
Liqquid's Avatar
I don't have an MR, but on my 5 speed I noticed much better shifting after installing the brass shifter bushings and metal shifter base bushings, along with bg syncroshift. It was really notchy before adding those.
Old Mar 25, 2009 | 06:56 PM
SoflaEvo9's Avatar
i run a 5spd and every morning i have problems getting it into 2nd. i usually just let the car warm up for a little longer than average in the cold mornings, although I do live in FL so its not THAT cold...
Old Mar 26, 2009 | 05:41 AM
dgrumpys's Avatar
Grind
ok so is the consensus generally speaking, that until trans at complete warm operating temp, notchy and partial shift grinding is normal?
i know theres threads out there about the best fluid to use to try and protect our internals, but anyone want to chime in about there favorite trans fluids?
BUMPITY
Old Mar 26, 2009 | 06:36 AM
monkey_187's Avatar
I dont think that any grinding is normal at all IMO. I had my car fixed it took them one day to say it was a tranny problem, then they had to take it off and rip into it.
