Which turbo kit would you choose?
Old Mar 12, 2009 | 10:40 AM
  #46
blownevo's Avatar
Ok i see.....so the FP Red is the way to go...is the ETS kit not capable of 500 whp?
Old Mar 12, 2009 | 10:42 AM
  #47
Celica2EVO's Avatar
mellon is also on a $20k + Buschur build, our cars arent cheap to get the pump gas 30psi numbers we are putting down! its also alot of maintenance and upkeep!
Old Mar 12, 2009 | 10:52 AM
  #48
mugen777's Avatar
Mellon was running 30psi on straight pump on the STOCK block before his build.
Old Mar 12, 2009 | 10:53 AM
  #49
mugen777's Avatar
The ETS kit is more than capable of reaching 500whp.. depends on which turbo you pick.
Old Mar 12, 2009 | 10:55 AM
  #50
tkuoha's Avatar
geez man, tbh, if you're on a budget, the 500 whp on pump isn't it. I think you'll be impressed with a stock frame turbo, and if you want a lil more power go with the full-race manifold. I think a lot of people under estimate how much 400whp is, they somehow think its slow. The BBK and Red will for sure impress you.
Old Mar 12, 2009 | 11:05 AM
  #51
mugen777's Avatar
^^^ Tis true... If money is an issue I would go with the Red or BBK. Honestly if you aren't willing to set back some cash for a built motor then I wouldn't get a larger turbo. Give the Red or BBK a shot see how you like it I am sure you will be happy. It will blow your stock turbo out of the water...
Old Mar 12, 2009 | 11:12 AM
  #52
blownevo's Avatar
Are precision turbos any good?
Like the kit from Boostlogic.
Old Mar 12, 2009 | 11:14 AM
  #53
blownevo's Avatar
I can dish out a few more hundred, but not enough to build the motor. Thats why im asking if I should go with either ETS, FP Red, or the boostlogic kit from the first page.
Old Mar 12, 2009 | 11:42 AM
  #54
denver's Avatar
Yeah you have a point, but I want more power than a green and they say red has lag issues.
IDK, any other suggestions guys? Thanks for the help so far by the way.
No way would I ever describe the RED as "laggy" I had one, and it is an excellent sized turbo for this car and youll be in the 500 to 550 range with it and its by no means laggy, especially compared to the two turbos you are looking at....
by far one of the easiest and least expensive ways to get a larger turbo for sure....
Old Mar 12, 2009 | 11:52 AM
  #55
ETS Michael's Avatar
I would recommend one of our ETS Super Value 3076 or 3582R Turbo kits depending on the spool and power you are looking for?
Spool on a 3076 will be around 4200-4300 on a 2.0L, where the 3582R will be closer to 5000rpm. The good thing about going with a turbo kit rather then just an upgraded turbo is the fact that you can UPGRADE later for much cheaper.
The ETS super value turbo kit allows you to go from a 50 trim style turbo to a 61 and even a 67 with the change of a motor mount. We offer a lifetime warranty on all our products and back it up with some of the best customer service in the business.
If you are like most people I talk with they go for the bolt on turbo, then they want more power or more top end power. It's definatelly cheaper to just purchase a direct bolt on T3 style turbo on your next upgrade instead of buying just the turbocharger now, then having to buy a complete kit later on WITH another turbo. You will also be able to run any of the HTA, Precision or Garrett turbo's that fit into that category.
If you have any questions about which turbo to go with feel free to give me a call, pm or email!
Thanks!
Michael
pbassist12
17
Mar 28, 2011 05:21 PM
ch53avitech
May 14, 2008 11:23 PM
Asmodeus6
14
Dec 17, 2007 04:19 PM
Asmodeus6
Nov 5, 2007 11:18 AM
LancerShop.com
27
Mar 19, 2005 07:07 PM
