tial waste gate??????
Old Mar 14, 2009 | 12:27 PM
evolve_VIII's Avatar
so i just built a turbo set up and i have a tial external waste gate. at idle the waste gate is dumping exhaust. is this normal?? while cruising down the road its still dumping and barely makes boost. if i accelerate hard and let off the throttle the waste gate closes and is quiet. i dont know if this is what its supposed to do... any help would be great. thanks
Old Mar 14, 2009 | 12:29 PM
Munch's Avatar
Something is wrong with your WG. It's not supposed to dump exhaust until it reaches the set spring pressure boost. Mine opens at 14psi. Hope this helps you.
Old Mar 14, 2009 | 12:41 PM
ScorpionT's Avatar
Sounds almost like you havent got a spring in your WG. That or your spring is really soft.
Old Mar 14, 2009 | 12:45 PM
i will look into it. doesnt it come with a spring when you buy one?
Old Mar 14, 2009 | 12:52 PM
Munch's Avatar
Yes it does. Just take it apart and check. It might not be completely seated, and causing a leak.
Old Mar 14, 2009 | 01:02 PM
i will do that asap. thanks for the info
Old Mar 14, 2009 | 01:20 PM
Munch's Avatar
No problem.
Old Mar 14, 2009 | 01:57 PM
Steve93Talon's Avatar
I'll bet a dollar you didn't install the valve seat/sealing ring.
Old Mar 14, 2009 | 03:01 PM
Chris@nolimitmotors's Avatar
Originally Posted by steve93talon
i'll bet a dollar you didn't install the valve seat/sealing ring.
+1
Old Mar 14, 2009 | 04:04 PM
evokid511's Avatar
5 bucks says if its the old style he doesnt have the fire ring in which doesnt allow the stem to seal all the way... i no this cuz it just happened to me today haha
Old Mar 14, 2009 | 04:10 PM
Pure Playaer's Avatar
There could be something wedging your wastegate open.. It wouldn't be the first time I've heard of this happening.
Old Mar 14, 2009 | 04:27 PM
evokid511's Avatar
do you have a pic of the bottom of the wastegate?
Old Mar 14, 2009 | 06:45 PM
evokid511's Avatar
any update yet?
evole97
Sep 1, 2015 07:11 PM
foxmr
Nov 6, 2008 08:11 AM
filter
Oct 3, 2008 07:14 AM
