Cylinder head testing - Part 1 - 823 whp base line on HTA88
Old Mar 21, 2009 | 04:26 PM
  #106
DynoFlash's Avatar
Originally Posted by davidbuschur
Scorke, while I may have been a bit sarcastic there was no hateraid in my post or anything nasty. I'd be glad to carry on a conversation and post my thoughts but every single time I do you argue with me and tell me I am wrong. I thought I'd try something new and just agree with you and tell you how smart you are.
I have run air to water intercoolers NUMEROUS times in the past, got caught up in the drinking the cool aid myself. Each and every time I did I switched back to air to air again. I watched some cars get changed to air to water intercoolers last year.............this year they are also changing back to air to air, it's not even humorous to me, I knew it was going to happen before it did.
There is more to it all than "cold water makes power".
It's interesting Al is running a twin scroll turbo on his car and has talked about how great the spool up has been...............now with the boost levels backed down 7 psi the power level is close to what it was. Twin scroll.....................another topic I have tried to input information into with little to no success. Make it spool up great and the top end suffers.
We run the same compressor wheel AL is running in his turbo in our black car, different turbine wheels but similar in size. I can assure you that compressor wheel combined with our single scroll turbine housing made excellent power at close to 50 psi when our car ran 166 mph with the same compressor wheel.
The cool aid, it doesn't taste the same to everybody. Some of us like grape, some of us like cherry. I guess it's best to each pick their own flavor and not hassle the other one about what he likes.
I am very open minded to the concept that the twin scroll is hurting my performance but from everything I have read and researched I can not find any data which supports such a proposition. I can agree that perhaps on our application twin scroll may not be as beneficial as on a V8 engine for example - however - from an engineering perspective the concept no doubt affords a distinct advantage, at least that is my feeling based upon my reading.
I am always open to suggestion and new ideas.
Al
Old Mar 21, 2009 | 04:29 PM
  #107
DynoFlash's Avatar
Originally Posted by twkdcd595
Just a side thought on the topic of nitrous, you could run a nitrogen assisted setup that does not require you to have to worry about heating bottles or any of that to get it up to pressure and maintain stable pressure throughout a run.
At the end of the day, NOS is a great concept it requires a lot of effort from my experience.
Not to mention the time I did a back fire at ATCO and blew my intake, fmic and fmic up in one shot and also **** in my pants.
Al
Old Mar 21, 2009 | 04:31 PM
  #108
dan l's Avatar
Thank you for the continued education Scorke, I appreciate it. Soon, if I keep listening to you and try very hard, I could with the grace of God, actually own or atleast maybe build a fast car. I may even get lucky and be able to build one that can do more than run for a few seconds at a time for just a drag race. I'm going to pray tonight for help but for now I will just give thanks to be able to read your posts. Thank you so much.
Have a nice day.
I was wondering how long the "new and improved" david buschur would last. Thank you so much.
Old Mar 21, 2009 | 06:01 PM
  #109
DynoFlash's Avatar
This is a technical thread - please refrain from going with nonsense
Old Mar 21, 2009 | 06:30 PM
  #110
Ted B's Avatar
Originally Posted by DynoFlash
Its interesting how we both have the T4 twin scroll set up - its a great spooling combo for sure. Are you also running the Shearer manifold ? Any pics of your set up ?
I'm using an MPFab manifold, which is somewhat similar to Shearer's work. Pics can be viewed here: Ted B's Setup
BTW Al, regarding the small difference between 40psi and 47psi with your setup, you're probably just plain out of turbine side at that power level. There could be other factors involved, but that's where I'd point my finger. There may be some merit to an earlier suggestion that your testing includes runs at 30 psi as well, just so the turbo has enough headroom in it so that improvements can be realized. If the turbo is out of puff at 40psi or if turbine side backpressure is high, a better head probably won't make a difference at that point, and the results could be misleading.
4g63dsm,
I agree with you on the flow bench. It certainly proved nothing at all when it came to the intake manifold testing I did, it was basically worthless.
David, the reason why one sees a great deal of headflow data in the industry and virtually zero flow data for intake and exhaust manifolds is because unlike the ports and valves of a head, the potential of manifold runners and plenums is governed by pulse wave tuning. This makes for a complex scenario that cannot be gauged with a steady stream of air (i.e. a flowbench). Think of it as trying to determine the sound quality of a trumpet by just blowing air into the mouthpiece instead of playing it. It won't happen.
Old Mar 21, 2009 | 07:22 PM
  #111
HeadGames's Avatar
Dave are you saying you seen nothing from a increase of flow in the manifold from the bencg to the dyno?
I have flowed a bunch of manifolds over the years, and always flow them on the head. Usually it will knock the cfm down, sometimes as much as 40cfm. Port it, pick up a bunch of cfm on the bench, but only in the LS1 did we not see a increase of power. I also seen in rare occasions the manifold would actually only knock the head down 3-10 cfm. and porting did nothing. I like Ted's explanation. It makes sense, what doesn't to me is why it seems to not always be consistant from motor to motor.
Old Mar 21, 2009 | 07:52 PM
  #112
DynoFlash's Avatar
Thats why they call it headGAMES Its a fascinating subject for sure.
I am sure excited by my project but the amount of tuning work I have to do is making my progress on my own car very slow.
Hopefully I can get moving on this.
Al
Old Mar 21, 2009 | 09:57 PM
  #113
MRfabolous's Avatar
hey al what kind of ignition are you using i thought i seen stock coils in the first pic thanks.
Old Mar 21, 2009 | 10:39 PM
  #114
HeadGames's Avatar
AL..be happy you don't have time to work on your car. i have been trying to get to my own heads for my Vette for weeks, wish I had the time. But when I think about how the ecomony hit us earlier this year, and how everyone is slow or out of work or even closing up shop..we gotta take the work with a smile!
in the interm..we have some good conversation going on.
Old Mar 21, 2009 | 10:54 PM
  #115
DynoFlash's Avatar
Yes - stock coils and wires with HKS twin fire - BR8ES plugs gapped tight
AL
Old Mar 21, 2009 | 11:00 PM
  #116
DynoFlash's Avatar
I agree with you 100%, I really appreciate the passion and determination of our customers who have continued in the car performance and modification hobby despite the weakness in the overall economy.
I can only speak for myself when I say that I have not stopped my car modification process one bit and I am just as fired up as ever about my Evo and continuing to find ways to make it run better.
Al
Old Mar 22, 2009 | 08:54 AM
  #117
4G63DSM's Avatar
See below
Old Mar 22, 2009 | 08:56 AM
  #118
4G63DSM's Avatar
AHH,,, no, you sir are incorrect. Just plain wrong. First off, the ports in the head are subject to the EXACT same pressure waves as the manifolds. Your "pulse wave tuning" which I believe is called "resonance tuning" that you speak of is not isolated to the runners of the intake manifold. The pressure waves "bounce" off the back of a a valve and the low pressure zone ( as relative to the runners) in the plenum ( as an example of one sort of resonance). The entire length is subject to this phenomenon. A gasket between the head and manifold doesn't effect these waves. You are correct, however when you mention how complex these waves can be. In most four valve cylinders, there is multiple waves bouncing through the intake system. The closing of the exhaust valve causes a wave, scavenging from valve overlap can cause one, the intake valve closing can cause one as well. These waves happen in both the intake ports and exhaust ports. Further more, there can be yet another wave forms from the plenum through TB and intake ducting. Any area where volumes, and ducts come together is surely to create a resonance of some kind. The trick is to get all the resonance waves working in harmony and the rpm you want. This is how F1 cars achieve 140% VE. It's not magic, its science.
There are many ways to actually calculate these resonances, the easiest being some quick formulas for a helmholtz reso, while software packages like Ricardo Wave, and AVL boost, GT power, can calculate these based on 1D estimations, or be coupled to a decent 3D CFD package to get more accurate results.
Since I use the Ricardo Wave and Vectis package a lot, I can speak to the terrific correlation between the simulations and actual dyno results. The rough hand calculations, usually get you in the ballpark, but not nearly as close as Good software..
One more thing, If AL gets to test a lot of cylinder heads, I would wager that the best performing heads are those with more work focused on the valve seats and combustion chamber, rather than the ports themselves....
Old Mar 22, 2009 | 10:00 AM
  #119
Ted B's Avatar
Just you you'll know, I frequently simplify concepts and terms for the benefit of the masses, which is why I resort to more visually descriptive expressions such as "pulse wave tuning". I am well aware of the role the ports, valves, valve timing, runners, plenum, and such play in the composite resonance scheme, but I deliberately chose to simplify the picture with an easily visualized analogy for this short blurb. Nonetheless, I should carefully note that the head isn't isolated from resonance if I implied otherwise. Thank you for the comment.
You are correct, however when you mention how complex these waves can be. . .
Which is exactly why I refrained from initiating a lengthy, heavy treatise on the complexity of resonance smack in the middle of Al's topic. Resonance is a tremendously interesing topic, and worthy of months of discussion and speculation, but not necessarily here.
Carry on . . .
Old Mar 22, 2009 | 11:55 AM
  #120
scorke's Avatar
Ricardo is soooooo dope, I wish I had a copy of a couple of their software packages.
Scorke
