Synapse BOV
I never had stock IC piping and never seen this pipe going into the LICP. What is it for? Why don't I have it on my car right now haha.
I'm praying A + B blocked or B + A blocked will work for me, might have to ditch the BOV if not. How would I go about blocking the port? I am not that experienced of a mechanic and don't wanna do something stupid.
before I changed turbo kits I tapped the LICP right after the turbo and put a nipple/barb fitting for C port...worked very well as the C port had a dedicated line w/no T's in it. I'm glad i'm not having problems like other people are having. Synapse has a tech forums you can register and post up any questions/problems..or call them.
I have mine setup similar to evodude's.... http://evoempire.org/index.php/topic...89&#entry96189
I have stock like UICP (dejon), cut up some hoses and connected to the stock intake with an elbow
the nut is only used as a lock nut, you will need a allen wrench to loosen the preload screw on the spring.
- clockwise tightens
- counter clockwise loosens
I had about 5 threads showing when I received mine. The syncronic likes to be set soft according the Synapse, so back the screw out pretty far...
-GL
-GL
Mine was touching the end of the thread but very very loose. So I should slide it up more? Is this going to make a significant difference in anything? I don't understand enough about how exactly BOVs work.
And btw, doesnt that nut move around if its so loose? Slide up and down over time from all the shaking?
I really wonder what the improvement is of C blocked, it honestly makes no sense. I thought that was the whole point of the BOV haha.
Anyway, update.
So I drove out and tested different preloads, maybe got out of my car like 8-10 times. I found some REALLY good sounding shifts at higher boost. However lower boost is better, but not great by any means. I however broke my Tee and have no more so I can't try A+B until I go get another one. So far best for me has been like 3.5-4 theads showing on the preload screw. It got really bad above like 6 threads I'm guessing, I didnt take a good look when I did it.
I will wait until I get a Tee and then try again and maybe go get a nipple made on my LICP but I don't really think that is too necessary.
Anyway, update.
I have tried all variations this valve has to offer and found that port B hooked up to the intake manifold and port C hook up to the nipple off of the compressor pipe worked best.
I wouldn't call it flutter. The valve did flutter on every other variation. The only downside I see in this valve is that it opens too easily which is where it bucks slightly. I can live with that compared to every other valve failing on my car.
I'm trying to figure out if you "really" need a mini batt to run it horizontally.
